Ollie..... .....CAUTION: selecting the "wrong" tabs of yer fullwave bridge will pass the volts THRU the bridge from the guttz of the alternator to the ignition coil and you will NOT beable to turn yer engine OFF. Bridges have polarity, just like diodes and batterys. As I said, mounting a single diode is trivial to a techo-geek. I must be one, since I built my first radio receiver in 1952. Thats over 50yrs of electronics, and you know what? I still gitt that solid state diode installed backwards sometimes. That is why I recommend the "idiot-lite" 'cuz it works NO matter which way you wire in the litebulb wires. You only need about 0.1-amp of switched excite current to make the 3-wire alternator start charging in less than 1-second of excitation. Once the alternator starts charging, the diode has NOTHING to do until you want to turn yer engine OFF. And since it is "reversed", it won't pass enny volts/amps and yer ignition coil will STOP-SPARKIN' and yer engine stops turning when you turn yer ignition key OFF. Amazing, eh?..... ...respectfully, Dell, retired Boeing Flight Test Engineer and 50yrs techo-geek
