Order Ford 8N Parts Online
NAA / 8n interchange
AZ Ghost Town
11-10-2005 06:33:34
My NAA self destructed the rear end, pinion gear bearing seat. I found an 8n rear end, complete with gear and axle. Any chance this will bolt up to an NAA. Thanks
Scott PA
11-10-2005 18:10:26
 Re: NAA / 8n interchange in reply to AZ Ghost Town, 11-10-2005 06:33:34
So far I have been able to salvage all the ones that broke out by having it welded back together, if you can't weld yours and can't find any used housing click on my name to email me about a source.
Ramrod
11-10-2005 14:34:00
Hey AZ, it just might be yur lucky day. Old Warrior has a shiny new ring and pinion gear, and I still have the old set which has mucho life left in it, although it is not a matched set as OW now has. The ring gear is near perfect, the pinion gear is also great, only thing wrong is the bearing retainer groove is chipped, but on the new pinion the bearing is welded on, so that would be a great way to fix that chip. I have no bearings to go with it, but the gears are available.
Ramrod
Dan
11-10-2005 06:40:33
No, the NAA has three different chambers - transmission, hydraulic, and differential - whereas the 8N shares this chamber between all.
Dan
AZ Ghost Town
11-10-2005 07:16:10
 Re: NAA / 8n interchange in reply to Dan, 11-10-2005 06:40:33
Thanks Dan, I was doing some wishful hoping this was a possibility. Found this part on ebay, may be a good deal for someone.
http://cgi.ebay.com/COMPLETE-8N-FORD-TRACTOR-REAR-END-GOOD-WORKING-COND_W0QQitemZ7560658096QQcategoryZ111488QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
