right hand thread
Dell (WA)
11-11-2005 00:01:04
GOM..... .....yer 5/8-18 crankshaft pulley bolt is standard righty-tighty lefty-loosey thread torqued to an AMAZINGLY TIGHT 150ft/lbs.
BIG TIP: stuff some soft 1/4" rope down enny sparkie hole so the piston will stop the crankshaft from turning so you can loosen or tighten yer crankshaft bolt. OTHERWIZE yer crank will spin in the engine and you won't beable to remove yer crankshaft pulley bolt..... ....Dell
