need hydraulic help
appleknocker
11-11-2005 18:21:43
with a scraper blade on the back, the lift on my naa is hesitant to lift, but once it begins to come up, it is very slow. it is slow even when i pull the throttle back to rev the engine. with the blade in the air (raised), the lift will lower slowly (bleed off) while the tractor is idling. what should i look for? thanks.
Dan
11-11-2005 19:14:15
 Re: need hydraulic help in reply to appleknocker, 11-11-2005 18:21:43
More than likely - your piston O-Ring is worn and fluid is leaking past it. Pull your left hand inspection port off and watch the end of the piston opening while the lift has raised the blade off the ground. There should be little to no oil leaking out of the end of this piston cylinder.
If it is not leaking here - note where it is squirting, leaking, or flowing. This will help in your troubleshooting.
Good luck,
Dan
