Governer compensating spring question....
Alvin Roberts (
11-13-2005 07:59:52
third party image
I am wondering what exactly is the purpose of spring in the picture I have posted? My 47 8N does not have this spring on it. Is it supposed to? I have noticed that in the few times I have ridden the tractor since I got it, I have to keep moving the throttle lever back up to maintain speed....it will just continue to creep back down. I was wondering if this spring would solve that problem?
Dell (WA)
11-13-2005 08:53:41
 Re: Governer compensating spring question.... in reply to Alvin Roberts (MS), 11-13-2005 07:59:52
Alvin..... ...yep, governor compensating spring, p/n 8N-9827, 4.95" long by 0.44 dia. They usually break at the throttle shaft pinchbolt connection. And you know, I don't remember wheather thats an adding or substracting spring configuration.
I do know that yer pinchbolt throttle rod lever can loose its grip on the throttle rod and diss-allow the throttle notch pointer friction in the notched throttle plate on the dashpanel under yer steering wheel. Its a trivial exercise to re-set yer pinchbolt throttlerod lever for slightly tighter throttle rod spring compression..... ..Dell
