Brake srping thru finger....ouch!!
JohnJ_PA
11-13-2005 15:17:01
Well, I was installing new brakes on my 8N and one of the springs cut loose and the hook of the spring went right through my index finger. Man did that hurt! That's the first time my 8N drew blood...pretty good considering the refurbish is almost done. I have since found a safer (and easier) way to install the springs. Be careful out there! -JohnJ
Rick H. Ga.
11-14-2005 11:00:12
 Re: Brake srping thru finger....ouch!! in reply to JohnJ_PA, 11-13-2005 15:17:01
Real nice restoration there, John. Thanks for sharing the pic's, they were great.
Rick
Hank ABAB
11-13-2005 17:15:48
What kind of primer and paint are you using? Are you spraying it on? Looks great!
JohnJ_PA
11-13-2005 17:23:56
 Re: Brake srping thru finger....ouch!! in reply to Hank ABAB, 11-13-2005 17:15:48
I'm using Rustoleum grey primer (brush on) and Rustoleum Sunrise Red (both brush on and spray can). I used the primer on everything (including the engine). The head and head bolts were powder coated and the manifold was ceramic coated. I have about 3 hours on the engine and no paint peel or discoloration on anything (yet). -JohnJ
Russ SoCal
11-13-2005 16:54:47
 If that red is yer blood..... in reply to JohnJ_PA, 11-13-2005 15:17:01
....can I buy a gallon?
Looks beautiful, John.
Link is fer "next time."
Russ ;0)
FarmerDawn
11-13-2005 16:23:31
It's beautiful, John! I'm sorry to hear it "got" your finger, though. I'm thinking those springs are under a lot more tension than I realized!
Hobo,NC
11-13-2005 16:20:45
The freeze plugs still bulge out a bit. I was afraid to hit them too hard (scared I might crack the block). All OK ..no leaks. Didn't use any sealer on the freeze plugs or on the oil fittings. You will not crack the block iffin ya hit’em to much actually you will make the plug fit to loose iffin ya hit’em to much. That’s the way ya git’em out izz drive the center in till it frees up. I would have put sum sealer on'em but thats yer call, Nice job look'in good
In my first years Of mechanic‘in I had to git stich’izz quite a few times, now I git a few scrat‘izz now and again. My doctor had a nick name I gave’em Dr. Infect cuzz enny time he stiched me up it got infected had to be him cuzz the grease and dirt could not have had enny thing to do with it.
Marty 2N IL
11-13-2005 15:55:51
Wow! Great looking tractor, almost there!! Post more pics of the tin.
Marty
FLAcharlie
11-13-2005 15:50:20
Beautiful pix. I marvel at what some of you guys do in restoring, I just mow the field with mine...
RE: "I wish the aftermarket manifold had an 8N part number instead of the 9N. Oh well."
I don't know about THIS particular part, but an awful lot of the 8N parts are actually "9N" part numbers, it's not necessarily an indication of some kind of mismatch.
Tom in MS
11-13-2005 15:33:06
Good looking work going on there..I found a safer way to get the springs on my 2N also..I took it to my friend/mechanic and he did it for me..
