In the morning I am going to take a look at the blades on my bush hog. Never done this before. I know its real heavy and need to be safe. It is parked next/under a lage pine tree. I was planning on using a 4 ton come-a-long to lift it towards the pine tree and and then secure it with 2 log chains to the tree while bracing the other side up with some 2x6's.Now my questions. I am sure the blades are in lousy shape, they are 15 years old at least, maybe 18 years. 1. Based on their age should I just replace them or if would I be ok just grinding them? 2. If I grind them how do I ballance them? The blades are free floating (bolted to the arms) 3. Are the blades are Quality Farm good to use? 4. How tight should I bolt the blades on when I put them back on? Just tight enough to let them swing freely? 5. Should I plan on just replacing the bolts due to their age? 6. Any other thoughts? I am expecting the bolts to be a real pain to get off. Thanks.
