One step forward....Spent a long weekend at the farm “wrenching” on the vehicles. I use that expression deliberately since fixing would imply that I have the slightest idea of what I’m doing:-) Did succeed in changing the fluids in all 5 vehicles. The guy at the recycle/haz waste site was bit surprised as I kept pulling 5 gal buckets of stuff out of the truck. 40+ Gal. Have to say the Ford 8N was by far and away the easiest to work on! Except for that 2” drain plug on the tranny. Quite a gush!. But thanks to this board I was warned..... . But alas not everything goes as planned.... Managed to take a perfectly running tractor and make it stop running... Ford 8N, 1949, Front mount 4 nipple 6V positive ground. New to me. Tractor started and ran fine. Changed fluids still ran fine. Replaced oil pressure gauge, still ran (and 35 psi @ 1500 rpm). Then I replaced the headlight switch.... The tractor has been rewired in a fairly half baked way. Found a 15A household screw base fuse in series with output of ignition switch. Traced headlight wires, measured with the volt-meter that the switch was intermittent. Replaced switch, headlights worked. But now it won’t start. Cranks fine with gusto! Spark test weak to none. Started poking around with voltmeter, found wire from ignition sw to coil to be flaky. It had been rubbing/melting on block and as I wiggled wire the 6volts on the coil would come and go. Replaced this wire with a new wire (18ga) from ignition switch directly to coil. Still no start. Voltage on coil with ignition switch on was -5.6V static, -5.3V cranking. (all voltages ref chassis) Checked for “week sister” ignition switch, only 150-200mv drop across switch when cranking, 400mv with headlights on. Then noticed that one of the nipples on the distributor cover was cracked. Spark plug wire was still connected but the phenolic housing was cracked away on one side. About this time noticed the delightful smell of hot electronics. More a capacitor oily kind of smell, not the cooking resistor kind. Felt the coil and it was quite warm. Cooled down when I turned off the ignition. Let it cool, tried again. After leaving ignition switch on for 6-7 min coil was hot. Tar was oozing out the side, don;t know if it was there before. Another observation was raw gas dripping out of the carb. Coming from an indentation near the drain plug. Never noticed this when it was running, on the otherhand I was in the seat driving along so I wouldn’t have noticed. Not sure this is related or not. I’ll guess not since I turned off the fuel cock as it was cranking away and cleared the gas and it never even coughed.
Opinions?
Thanks as always
