Fan Shroud
banj53
11-23-2005 14:49:22
My '52 8N is missing it's fan shroud. With just a small garden to work up and the very seldom used 5' scrape (for snow removal) I'm thinking maybe it would be no problem to keep using without installing a shroud. The tractor has shown no signs of over-heating, and the radiator does not leak. But, the party that just painted my hood and grill told me that it looked like the radiator wouldn't last much longer. Thanks for any input.
Dan
11-23-2005 14:55:48
 Re: Fan Shroud in reply to banj53, 11-23-2005 14:49:22
Nobody can look at the outside of a non-leaking radiator and tell you how long it will last... Unless you live in a VERY warm climate and do a lot of slow heavy low RPM mowing in Summer time, your 8N will cool just fine without a shroud. Remember, the cooling system on our 8N tractors or overkill.
Make sure you have a thermostate installed and working.
Good luck,
Dan
Rick H. Ga.
11-23-2005 14:53:06
Hi Banj53,
I have owned my 49 8N for about 29 years and it has never had a fan shroud and has never overheated.
Hope this helps,
Rick
