Finally frustated
Ron/PA
11-26-2005 12:11:25
Grabbed the 8N this morning to get some work done and it started missing at high rpm's. Points, plugs, condenser, wires, and still the same. Spoda be warmer tomorrow, so I'll clean the carb then. Sudden thought just hit me, that I replaced the coil a couple weeks ago, and she hasn't done any work since then... could be I gotta re-try the old coil as well. Ron
RoNofohio
11-27-2005 18:51:19
 Re: Finally frustated in reply to Ron/PA, 11-26-2005 12:11:25
If it's just missing at high RPMs, it could be that the spark advance weights in your distributer are sticking. Like maybe a screw is interfering or something. You might want to pull the distributer one more time to check them out. You'd have to pull the points plate out to get to them, and they should be spring loaded and set up to move outward by centrifigal force at higher RPMs..HTH...JMHO...Ron
old
11-26-2005 14:14:05
Let me guess its frount mount dist. If so I'd almost bet your points sliped, maybe a stripped screw which they just plain love to do.
Ron/PA
11-27-2005 04:42:09
 Re: Finally frustated in reply to old, 11-26-2005 14:14:05
That's what I thought too, but it happened before the tune up, and didn't get any better. Had the dist out 3 times and double checked. Didn't slip a bit. Right on .015.
Ron
FarmerDawn
11-26-2005 12:52:29
Aw man! I can see why that would be frustrating! I hope you are able to figure out what's wrong quickly and easily.
