Order Ford 9N Parts Online
9N Valves
Rick in MA
11-26-2005 19:54:14
I am currently rebuilding the engine on my '41 9N. How can I tell if the tractor has been retro fitted with the rotating valves as compared to the original non-rotating jobs? It does have the newer adjustable tappets. I plan on probably just replacing the valve components and seats anyway, but was curious just in case the valves and seats are deemed to be salvageable. Thanks in advance, Rick.
Jeb2N
11-27-2005 05:37:48
 Re: 9N Valves in reply to Rick in MA, 11-26-2005 19:54:14
Bob is right. I believe that you have the old style "mushroom" tipped valves which were originally adjusted by means of grinding on the end of the valve or lapping the head in to adjust the clearances. That's how you did it with the solid, non-adjustable lifters. The adjustable lifters made life a lot easier as far as setting and maintaining valve clearances. AS bob said, if you see a small cup that kinda jiggles on the end of the valve stem, they are rotators. If you only have a cupped disc that holds the spring, you have non-rotating valves. Word is that the rotating valves last longer and seal better in working tractors. Mine is a show tractor so I just went with the regular straight valves.
Jeb
Bob
11-27-2005 09:01:42
 Re: 9N Valves in reply to Jeb2N, 11-27-2005 05:37:48
Jeb,
He says he has the one-piece guides, and if this is true, he cannot have the "mushroom-head" valves.
Rick in MA
11-26-2005 20:00:46
By the way, it also has the one piece guides.
Bob
11-26-2005 21:14:51
 Re: 9N Valves in reply to Rick in MA, 11-26-2005 20:00:46
The "rotating valves" have a little cup thingy at the lower end of the valve stem that contacts the adjustable tappet, rather than the valve stem itself.
Rick in MA
11-27-2005 16:34:09
 Re: 9N Valves in reply to Bob, 11-26-2005 21:14:51
Yes, I have the little cups on the exhaust valves. I guess they are the rotating type. Now I have to ask the machine shop of they are still good enough to be ground along with the seats. I hope so as it will save me a few bucks. Thanks for your help!
