Square nut removal on my rear tires..HOW?
Randy Bagrowski
11-28-2005 04:49:22
I have wheel weights on my rear tires held on by bolts with very rusted square nuts. Any idea, other torching them off how to remove them?
old9
11-28-2005 17:21:15
 Re: Square nut removal on my rear tires..HOW? in reply to Randy Bagrowski, 11-28-2005 04:49:22
Randy, What kind of weights? inside the rim? I have 5 of a 6 piece set. Wish you luck . Joe
Tom in Iowa
11-28-2005 15:58:05
Randy...just be very careful that you know where your hand may end up, if it slips off the wrench. Last October 8, I received a deep cut to my thumb, which I should have stitched up, but did not. As a result, a lesion known as a pyogenic granuloma developed, necessitating some surgery, including the removal of the lesion, removal of the thumbnail and a skin graft taken from another part of my thumb. BE CAREFUL!!!
Tom
Jerry Kirkpatrick
11-28-2005 08:59:50
Get 8-point sockets at Sears (Craftsman). They"re made for square nuts. If you bust a socket, take it back for a free replacement.
Good luck.
JK
Dan
11-28-2005 06:08:01
I use my Dremel tool with a cutting wheel to take care of problems like that.
Good luck,
Dan
Randy.Bagrowski
11-28-2005 06:48:52
 Re: Square nut removal on my rear tires..HOW? in reply to Dan, 11-28-2005 06:08:01
Thanks guys, I'll use my cut-off tool. I was hoping that someone would say...."call company xyz, they sell square sockets for your air impact wrench.."
old
11-28-2005 08:41:06
 Re: Square nut removal on my rear tires..HOW? in reply to Randy.Bagrowski, 11-28-2005 06:48:52
Well if you have impact sockets just try a few of them one will be very close but may need to be tapped on the just hit it with the impact gun. I've pul a lot of square nuts off that way.
Dan
11-28-2005 07:15:35
Well - I don't know how big the nut is, or what sizes/types of impact sockets you have - but a 12 point socket WILL fit on the square head nuts...
Good luck,
Dan
uh . . . Dell (WA)
11-28-2005 07:53:59
 yabutt . . . in reply to Dan, 11-28-2005 07:15:35
Dan..... ...a 12-pt 1" socket ain't gonna fit a 1" squarenut, probably take a 7/8" 12-pt. Sumptin 'bout the square of the hypotenuse, mox-nix. Besides iff'n that squarenut is that "rusted-tite", yer gonnna round-off the corners of the squarenut and the inner-corners of the 12-pt at the sametime. While not common, I've gott a few 8-point sockets that fit squarenuts and they are "beefy". Loosen-oil and air impact wrench with 8-point socket would probably work and beat the cuttin' alternative..... ..Dell
rbell
11-28-2005 08:03:09
 Re: yabutt . . . in reply to uh . . . Dell (WA), 11-28-2005 07:53:59
I got a 36" pipe wrench, and a 3 foot cheater bar.
Works great on square nuts
soundguy
11-28-2005 05:23:29
If you are trying to save the studs, then try these methods...
Nut splitter ( chinese tool store has them cheap ).
Hacksay.. say 95% thru the nut.. but not into the threads.. up and down.. then use a cold chissle to split them from the stud.
Coud try same with a file or dremel tool.. then chissle..
Soundguy
