Limiter chains and top link pin
StahlMaster
12-01-2005 19:44:10
I bought these limiter chains for my tractor:
third party image
The pin that holds the top brackets on is too short. Can I get a longer pin? This is the pin that hold the top link on.
Rip VanWinkle
12-03-2005 05:18:48
 Re: Limiter chains and top link pin in reply to StahlMaster, 12-01-2005 19:44:10
I just put the top chain brackets inside the tree. No need for a longer pin that way. The top link is between both brackets.
StahlMaster
12-03-2005 05:42:34
 Re: Limiter chains and top link pin in reply to Rip VanWinkle, 12-03-2005 05:18:48
Great idea! I"ll try that first.
FLAcharlie
12-02-2005 16:36:17
pin length aside, I got this exact same limiter chain set a year or so ago, and best thing I ever bought for my tractor. The other thing was the stabilizer bars.
StahlMaster
12-02-2005 16:43:24
 Re: Limiter chains and top link pin in reply to FLAcharlie, 12-02-2005 16:36:17
"The other thing was the stabilizer bars."
Where did you get these? Can you send or post photo"s of your hook-up?
FLAcharlie
12-02-2005 18:17:45
 Re: Limiter chains and top link pin in reply to StahlMaster, 12-02-2005 16:43:24
The stabilizer bars I got are the ones that go from the rear axle to the rear implement (not to be confused with any stabilizer bar things for the draw bar), I'll take a pic in the morning and post. Got'em at the local NewHollandFordWhatever place, the two of them were maybe $60 about a year ago, my memory could be off by a sawbuck. But before I had them, every time I went to make a turn in the field, the bushhog would run into the rear tires, very bad. Now, I can make as sharp a turn as I want, and that just isn't a problem. I'll post pic in the morning.
Kelly Jewell (KY)
12-01-2005 20:01:40
Stahl, the standard top link pin is 3/4 X 3 1/2 (9N-560 or 957E-560) and is in fact too short. This Kit idea was borrowed from Woods Equipment Co. and Woods recommended a 3/4" hex head bolt with lock nut and I agree. With a bolt you can take all the lost motion out of the straps as they take a beating when you drop the lift. My neighbor has broken several pins operating a 7 1/2' finish mower behind a 4 cyl 4000 but no bolts....Kelly.
souNdguy
12-01-2005 19:53:44
Most farm stores carry a variety of lengths of connecting pins..
Soundguy
Dell (WA)
12-01-2005 19:51:58
StahlMaster..... ..yep, the 3/4" x 2-3/4" N-toplink pin is just to short ain't it? YES, you can get several longer 3/4" toplink pins. Go shopping..... ....Dell
