Jubilee hydraulic problem
Alan
04-23-2001 08:51:21
My new Jubilee exhibits the typical Hiccups or bobbing in the Postion mode with a 2 bottom plow on it.It takes about 5-6 seconds for it to fall enough for the linkage to correct itself.If I raise it all the way up and then turn the tractor off it will slowly steadily fall to the ground in about 10 minutes..I took the inspection covers/filler plug off and looked as well as felt around the cylinder and could not feel or see a leak...I think the other possibility is the safety/check valve...but I am open to any other suggestions....If I do replace the safety/check valve do I need to replace the seat also????..and how easy is that to do..As always ....Thanks in advance...Alan
