Trickle charger question
ratropia
12-13-2005 13:08:47
49 8N. 6V. Pos. ground. I am having slow revolutions when starting my 8N in 10deg temps. But so far it still starts, because of this boards help for the last three years. Specially Dell and Sounder. I have a 2/15/150MA automatic battery charger with engine start. My questons is. If I put a trickle charger on it, do I hook it up directly to the Battery post, unlike jump starting? Or would it be best to not trickle charge it and just fully charge it if it gives me trouble starting? And while I am at it, should I ever use the 150MA engine start on the 6v system?
Thanks again for all the help. Happily (kinda) movin snow in MI.
Rick T.
Ole country Boy
12-14-2005 07:43:23
 Re: Trickle charger question in reply to ratropia, 12-13-2005 13:08:47
How about something as simple as putting your trickle charger on a timer. Comes on for say a hour each day, then off. Just a thought.
soundguy
12-14-2005 06:55:55
Not a bad idea to put the trickle charger on it an hour or two before you need it.. or overnight if you need it early am in freezing weather.. but i wouldn't leave it on all the time unless it was a 'tender'.
Soundguy
Wi Craig
12-14-2005 02:50:14
Don't forget to have the clutch depressed when starting that old girl when its cold. Burr!!
ThommyT
12-13-2005 20:00:19
I swear by DelTrans Battery Tenders as Gaspump alluded to. They make one for 6v and I just hook the black lead up to the black(NEG) lead on the battery and the red lead to a frame part or bolt that is not painted - for the POS ground system. Works like a champ. Don't have to do anything except unhook and start the tractor and when you're storing it again, hook it up again. It tends itself. Wish everything worked as well.
Tom N MS
12-13-2005 15:23:26
This is what I have and works great. Will not overcharge.. Link
Bad link
12-13-2005 17:32:05
 Re: Trickle charger question in reply to Tom N MS, 12-13-2005 15:23:26
This should work for 12v. but not 6v.
Tom N MS
12-13-2005 18:39:20
 Re: Trickle charger question in reply to Bad link, 12-13-2005 17:32:05
This is true...
Gaspump
12-13-2005 13:39:49
Never good to overcharge and weaken your battery. Might put the trickle charge on it few hours before starting but do not leave it on all the time. Neat battery maintainers are at batterytender dot com. Ain't cheap but best there is, site has nice FAQ info too.
