Yes and no. Yes.. e-ignition may bypass the problem concerning poor maintenance, and points... On the down side.. if you are 6v positive ground.. the electrical system really needs to be in 100% condition... or the module won't fire.. Barely enough juice there for the equipment to run as it is. Also.. if your distribuitor has excessive wear int he bushings.. or weights.. those will need to be addressed seperately. In the end.. it's your money.. but.. I find it simpler just to correctly maintain your points. I see dozens of posts here every month about people having problem with points.. it amazes me. Generally it comes down to electrical issues and cleanliness. My 8n has not had a new set of points in 5 years.. I do dress the old points and reset the gap about once a year... And heck.. even with a good ignition hone.. 'dressed' points aren't 100%.. yet my units run fine. I do this on my other tractors as well... gets a yearly dressing ont he points.. and go. I can't remember the last time I changed a set of points.. but it is generally.. only when I initially buy the tractor and tune it up. Gotta observe clean handling with points.. No dirty feeler gauges.. and don't use excessive grease on the rubbing block. I clean all my ignition tools in spray carb / brake cleaner.. -0- residue. If your points are slipping.. look at the screw.. Soundguy
