Studs
Alaska Jon
12-17-2005 20:39:13
Here's a question for the snowy season experts: I have calcium chloride in rear tires on my 2N(bought it that way, it's ok so far) but I don't have chains. Most of what gives me trouble is ice on the drive, my ag tires losing traction when I plow. Has anyone ever put studs into the ag tires, and if so, how did it work out?
Rob
12-18-2005 04:12:05
 Re: Studs in reply to Alaska Jon, 12-17-2005 20:39:13
I have taken my screw gun and put a bunch of hex-head sheet metal screws into my daily-driver tires. Those hex-heads bite into the ice good but they wear off pretty fast on pavement. By then the ice is gone away too.
You could put some big screws into those tractor tires and they would last longer without the miles on pavement.
gahorN
12-18-2005 07:08:57
 Re: Studs in reply to Rob, 12-18-2005 04:12:05
Yeah... and don't worry about any of those screws coming out and ending up in your wife's tires. (grin)
Rob
12-18-2005 07:15:26
 Re: Studs in reply to gahorN, 12-18-2005 07:08:57
Yeah, that is nothing to worry about since I showed her how to change a tire.
Dean
12-17-2005 23:49:50
I've never known of anyone to do this.
Years ago I installed studs into snow tires. The tires came with molded-in cavities into which the studs were pneumatically inserted. Of course tractor tires do not have these cavities. I do not know if snow tire studs are even available anymore as they have been outlawed in many states.
Tractor tires are designed to hook up with the ground and have little surface area. As a result, they are not well suited to snow and ice conditions.
The best traction aid for snow and ice for farm tractors is tire chains. Additional weight is a distant second.
Dean
