wheel weights
ROY CAMPBELL
12-22-2005 08:47:05
I LOOKING FOR INFO , I HAVE A 53 JUBLIEE AND I NEED INFO ON WHEEL WEIGHTS . ANY HELP ?
Dean
12-22-2005 12:07:29
 Re: wheel weights in reply to ROY CAMPBELL, 12-22-2005 08:47:05
Ford made both heavy (approximately 1,200 pounds) and light (approximately 850 pounds) versions of their Pie Weight system, so called because the segments resembled pie slices. Both, though not especially common, are readily available in the used market. The heavy version is also available as new reproductiopn.
Though all versions of these systems can be made to work with your Jubilee, Ford recommends only the light system for any tractors smaller than the 8xx series.
The going rate for a complete set of pie weights is about $500.
For quite a bit less you can load your tires with CaCl, water and RV antifreeze, or (maybe) the latest Rim Guard and achieve the same increase in ballast.
Dean
