Order Ford 8N Parts Online
8N ford tractor steering box
joey pintado
12-23-2005 09:43:02
Does anyone have a shop manual with a picture of a steering box broke down into pieces? I'm guessing this is my problem but not sure. It steers real hard to the left and about normal to the right. I have checked all the front end parts and they all seem in good condition. This tractor is an everyday use tractor.Not one that has set for a long period of time. Please help.
( Pic ) Ken N Tx
12-24-2005 05:10:55
 Re: 8N ford tractor steering box in reply to joey pintado , 12-23-2005 09:43:02
third party image
Hope this helps.
fnhtech
12-23-2005 11:35:30
Sounds like the upper steering column bearing may have failed. Not uncommon on these tractors. Requires removing the steering wheel, hood and dash panel to access the column tube. Remove the four bolts securing the column tube to the steering box and lift the tube off the column. Bearing race is in bottom of tube, roller bearing sits on column shaft. Not all that bad to repair, generally.
