Order Ford 9N Parts Online
9N problem
Ardie
12-23-2005 16:50:38
I have a 48 9N, it starts,runs but will not excelerate when the throttle is opened up. Governer seems to good and distributor advance is good. What is my problem??. Thanks for your help.
ratface
12-24-2005 13:41:32
 Re: 9N problem in reply to Ardie, 12-23-2005 16:50:38
can you make it accelerate by playing with the linkage?
Dell (WA)
12-23-2005 17:23:03
Ardie..... ....I know what you wrote makes sense to you, but this great N-Board doesn't charge by how many words you use to describe your problem. I flunked mindreading, just ask my ex-wife of 32yrs.
How do you know your governor is NOT the problem? Prove-it!
How do you know your distributor is NOT the problem? Prove-it!
BOTH the governor and the distributor can be the basis for your complaint of "will NOT accelerate". But so can dragging brakes and miss-adjusted carburator. Prove your assertions..... ....respectfully, Dell
Tom N MS
12-23-2005 17:15:21
48 is a 8N...Tell us more. Was it running then just started doing this or has it been sitting for years..etc..What about gas? Is it flowing a steady stream to the carb. and through the carb.? Have you checked the filters?
