Order Ford 8N Parts Online
want to paint ford 8n engine: looking for suggesti
jim gordon
12-23-2005 20:35:20
i sand blasted all the body parts & main body, im now trying to cleanup the engine, WHATS THE BEST WAY TO PAINT THE ENGINE? THANK YOU
Dan
12-24-2005 05:37:05
 Re: want to paint ford 8n engine: looking for sugg in reply to jim gordon, 12-23-2005 20:35:20
third party image
I have painted three engines - all with enamel and two with a brush. This one was done on the stand, and I put a second coat on after several hours when the paint was still tacky. This kept the second coat from running but still bonded well with the first coat and smoothed out real well. I prefer to paint on a working engine though. I still put two coats on in the same manner as above, but after letting the second coat sit overnight (still wet paint), I start the tractor up and run it for quite some time. The heat will actually smooth the paint to almost glass, and gives it a hard shell (baked enamel). It works great.
BTW - I brush all my cast iron unless I just happen to have it sitting out by a sprayer. I have done tractors both ways, and like the thickness you can get by brushing - and the rough cast iron hides the brush strokes very well.
Good luck,
Dan
Alvin Roberts (MS)
12-24-2005 03:24:06
I'm getting ready to paint my engine as well. I've got her cleaned up pretty good. I just need to degrease everything real well and I'll be spraying on a coat of primer and then brushing on the rest.
FarmerDawn
12-24-2005 04:42:48
 Re: want to paint ford 8n engine: looking for sugg in reply to ( Pic ) Ken N Tx, 12-24-2005 03:46:53
WOW, Ken! Beautiful job!
Dell (WA)
12-24-2005 01:41:22
Jim..... ....I like to suggest brush painting castiron 'cuz it don't show and you gittta HEAVY coat of paint that doesn't run like spraypaint does. Remember, you haffta thin yer paint to spray it, and you waste about 1/2 the paint in misty spray and not hitting the target. All other painting caveats apply..... ....Dell, the 20/20 painter (looks good at 20ft or 20mph)
souNdguy
12-23-2005 21:14:13
I think it's easier to spray the engine.. but I'll bet some prefer brushing.
Just get the loos paint and rust off with a wire brush, and degrease before painting.
Soundguy
Matt (MN)
12-23-2005 21:09:02
Before you start painting, I'd suggest running it and look for any oil leaks. Sometimes the valve covers can take lots of gasket sealer to keep from leaking. Once you know everything is good, then primer and paint. JMO
Matt
Kevin in Texas
12-24-2005 03:35:37
 That must be my problem.... in reply to Matt (MN), 12-23-2005 21:09:02
My 8n doesn't have a valve cover. Where can I find this thing of which you speak?
( Pic ) Ken N Tx
12-24-2005 04:16:27
 Re: That must be my problem.... in reply to Kevin in Texas, 12-24-2005 03:35:37
third party image
John Smith has some..
Here is his website link:
Kevin in Texas
12-24-2005 04:43:56
 Re: That must be my problem.... in reply to ( Pic ) Ken N Tx, 12-24-2005 04:16:27
I see, we have an issue with my description. I have always known those as side covers. My first reply was an early morning attempt at humor, as obviously, these flatheads don't have a "normal" valve cover like overhead valve engines do.
It's early, I'm still sleepy, you can all resume your normal viewing pleasure. The show is over, nothing here to see.
