Order Ford 9N Parts Online
1941 9N won't start
1941 9N
12-26-2005 06:55:55
Please I'm pulling my hair out! I put a 8 volt battery in tractor for easier starting! Tractor ran good for about 2 days. Then it spit and sputtered and died! The coil melted! I put a new coil on and added a second resitor in line to coil, so as not to melt coil! Thank You's for your help! ps. I need tractor to plow snow! tractor and car now stuck in driveway!
old
12-26-2005 08:34:36
 Re: 1941 9N won't start in reply to 1941 9N, 12-26-2005 06:55:55
Check and clean your points, when the coil melted it also probably burned the points. Your problem is just one more reason not to use an 8 volt battery. These old N will start in any weather if they are in good shape with 6 volt batterys.
