Peter..... ..1st-off, ya don't haffta remove yer N's HOOD to work on your squarecan 4-nipple frontmount distributor. Ittza 2-bolt, 15-min job to remove yer OFF-SET tang driven frontmount distributor and change the ignition points on yer mom's kitchen table. Just un-snapple yer 4-nipple cap and letter dangle. Disconnect yer single topmount coil terminal wire. Check and adjust yer frontmount ignition points gap = 0.015" on spred-out newspaper on kitchen table. Simple, eh? Installation is a reversal of the removal....except....gently fingerstart yer 2-bolts and then twirl yer rotor until it drops into the camshaft drive slot, now tighen yer 2-bolts. Snapp-onn yer crabcap and top-terminal coil wire. Simple, eh? Caution: be certain that yer points hold-down screw is the SHORT #8-32x3/16" screw. Also, the points screw gitts INVISABLE thread wear and can become difficult to tighten down enuff to keep the points gapp from slippin'. New SHORT #8-32x3/16 points screw p/n: 355047-S7 $50c (cheap) also available at yer local Ford Automobile parts store. Yer dads semi-right, yer squarecan ignition coil does run warm, not "burnie-burn" hot but noticeably warm in cold weather but non-noticable during hot weather. You must also run yer 6-volt squarecan ignition coil with the "infamous ballast resistor" under yer ampmeter. Otherwize, yer 6-volt coil OVERHEATS and pukes its insulative tar and looses its sparkies abilities. Suggest you squander summma yer xmas money for an I&T FO-4 manual. $22 (cheap) Readily available from sponsors of this great N-Board, most agricultural emporiums; Amazon.com, BordersBooks, WalMartBooks. www.n-news.com also has great archive of implement manuals. Even yer local CNH Ford/New Holland dealer sell'em, isn't that amazing? Even my local (byte my tongue) John Deere dealer parts counter is selling it. Gittcha one and readitt..... ...respectfully, Dell
