Wyatt..... ...8-volts is NOT UPGRADE!!! Think about it. Yer 8N's genny can only output about 7.4 volts, which is what it takes to charge a 6-volt battery. An 8-volt battery needs about 9.5-volts to charge-itt. Yer runnin' 'round on crippled 8-volt battery. I don't care what they tell you at the farm-store, just 'cuz some tractors can charge 8-volt batterys, not all can. It depends upon the genny design and yer 3-terminal 8N genny can't charge an 8-volt battery. Period!!! Intermittant sparkies is usually a cause of loose connections. It takes about 1-hr for a bad ignition coil to go bad. Since you claim you've been able to occasionally start yer engine, it ain't chur coil. As for the Chrysler resistor vs yer "infamous ballast resistor", use eather one or the other NOT BOTH. Understand? The Chrysler is slightly higher resistance which would be appropriate for 8-volts. But as I said; yer 8N's genny can't fully charge an 8-volt battery. Many times an 8-volt battery is used as a band-aide for a weak and worn low compression engine. Just as the popular conversion to 12-volts. It just spins the engine faster for higher dynamic compression and thus you think you've fixxed yer engine hard-too-start problem. FOOL!!!..... .respectfully, Dell
