Awesome Henry
12-31-2005 11:39:44
Re: Installing a Sherman.. in reply to Hobo,NC, 12-30-2005 19:00:11
Hobo, I wash the side of casting with thinner, mis some reisen and hardner, cut a couple pieces of fiber glass mat about 10 by 10 spray the casting with pam if you don't have any releasing agent, just a light coat over the area you are going to use for a pattern, brush on a coat of reisen lay out the cloth, brush it down good, I lay the matup on the front edge of the casting and back over the hole needed for the Sherman, make sure you have it wet enough to fit up good to every indentation, when dry mark the hole for the shift arm, as well as a hole or two on the front lip of the casting, for reference, pop it off, I always trim the edges, befor I send them to any body, they lay out super good on the casting, so far no one has ask me for casting, but after all I am the guy who made two mistakes this year, Awesome Henry
