Dell, its good to hear that their is that much meat around them cylinders, i have not ever opened up one of these engines so I didn’t know. With that in mind your right, supercharging does sound like a good idea. and no, I was not blowing off your idea about the smog pumps, I was just surprised to hear that some1 else was already doing it. like I said, when you get an idea like that it never seams long before you get word that some one else was one step ahead of you and already doing it :-( as for the bearings, yeah Iknow that the v8 flatheads also on had 3 and i am very aware of what they can do short term. I have liked them little v-8's ever since i was little and i have always had my eyes on em, just something about their sound, the nostalgia, infact i always wanted one with sharp aluminum heads, hunt mag, and either 3 deuces or hilborn injection.... but back to the bearings, personally I think that if I want to use this engine to have a long reliable life WORKING HARD on the property here the block needs to remain rigid, and their should be more main bearings (not like I am going to change that). This is my theory, the engine under heavy load in the flathead puts the load on the 3 main bearings, while a newer engine like a chevy places the load on 5 bearings and the main caps are held on with 4 or 6 bolts, with any hint of detonation which wouldn’t be unusual with an aggressive tuned supercharged engine it seams that a 3 main engine would have problems first due to more load placed on fewer bearings and the crank being less supported and thus more flexing, so in theory I would think that the mains would spin on the flathead first or just simply get pounded out. and yeah I know the bearings are wide on a flathead so the force is on a wider area, but I don’t think that helps much with a flexing crank. (and I have seen to many twisted and bent cranks from drag cars, different situation though) To aggravate the problem if you ever had low oil pressure and you couldn’t sustain an oil film on the bearings under that hard use your in trouble again, but that goes with any engine I still want to use a flathead though, but in my opinion its not a very good basis to make hp. but I am not going to push the engine with to many RPM's in a tractor so i would think it should be "ok" but definitely not ideal, btw, I have yet to hear a supercharged 8n 4 cylinder motor, i wonder what it sounds like with the stock cam.... Another thing I haven’t thought much about yet would be weight. the v-8 weighs more I would think (not sure with that cast oil pan on the 4 cylinder), so that might slightly help reduce the tendancy to raise the front end of the ground. Anyways guys I am not an engineer, I just love tinkering with old things and making things of my own creation and I am just thinking out loud, engineering does fascinate me though, if my train of thought is off I am happy to hear any comments.
