Gasket p/n???
Alvin Roberts (
01-01-2006 22:54:49
Could someone tell me what the correct part number is for the gaskets that go underneath the two rectangular plates that can be removed from the side of the engine on an 8N for access to the valves and springs? I need to order two of them but I'm not sure what the p/n is. Thanks!
Alvin Roberts (MS)
01-02-2006 06:33:08
 Re: Gasket p/n??? in reply to Alvin Roberts (MS), 01-01-2006 22:54:49
Thanks for the p/n Russ!
Russ SoCal
01-01-2006 23:17:08
Alvin,
Part number is "7HA 6521" for them square little things. No, I don't know why they have a weird prefix to the P/N.
Russ
Kelly Jewell (KY)
01-02-2006 07:41:28
 Re: Gasket p/n??? in reply to Russ SoCal, 01-01-2006 23:17:08
Russ, they started life as 9N-76521, but someone figured out they were the same as the car 6 cylinder, that were the 7HA came from....Kelly.
Russ SoCal
01-02-2006 23:46:41
 Re: Gasket p/n??? in reply to Kelly Jewell (KY), 01-02-2006 07:41:28
Thank you, Kelly. Got some last year from the local CarQuest, but didn't pay attention to the numbers.
Russ
