Paul..... ...last time to answer this post, start a new one iff'n you have more questions. ok? Ok, heers the deal. As I understand it, you have a 9N thats been converted to 12v. And the tranny safety interlock jiggle stick operated 2-terminal starter can switch under yer battery tray is MISSING. And you want to use a 4-terminal twist-to-start ignition key switch instead of the OEM 2-wire ignition switch. All that is ok, as long as you are fine with NO INTERLOCK. You want to use the later 8N's starter barrel mounted 3-terminal 6-volt starter solenoid. NO PROBLEM. To use the internally HOT 3-terminal starter solenoid, mount it NON-traditionally with the little middle terminal facing OUTWARD toward yer bellybutton. USE A HEAVY flat copper buss-barr to connect the starter barrel stud to the big starter stud facing it. Now connect yer 12-volt battery POSITIVE post with heavy 1/0 cable to the solenoid stud facing the driver. Now you can supply 12-volts to the little middle terminal facing yer beltbuckle from yer 4-terminal twist-to-start ignition switch ST terminal. Solenoid should NOT CHATTER. Why? 'cuz 12v on 6v solenoid is OVER volting its gonnna ker-whump but ain't gonnna hurt-itt. ok? Best as I can tell in all yer puttz'n-round, all you ever done is complain that yer starter solenoid clicks and NOT ONCE have to claimed to have yer starter motor whirr and turn the engine over. Well guess what? iff'n yer stater solenoid don't click and yer stater moter don't whirr, ya ain't gotts enuff volts. And 12-volts is plenty volts to gitter-dunn. The only thing in common that would cause solenoid clickin' and NO motor whirrin' is BADD-GROUND. And while you could have a BAD starter motor, make certain yer starter motor is well grounded first by splitin yer starter motor seam at the tranny hole and with a wire brush polish the seam. Understand? I used a fine rotory brush on a drill motor, but even a BBQ-grill brush will work. Now then iff'n yer 6-volt starter motor don't whirr when it gitts hit with 12-volts (it ain't gonnna hurt the starter motor) Then it would be my judgement that yer starter motor is BAD and needs servicing..... ....respectfully, Dell
