The toggle switch is a laughable idea... I can take a single wire with a set of gator clips on it and wire from battery to coil primary... doesn't mater if you have 50 cutout switches on it... Seems like a simple way to steal one is the same way we go pick up broken down models... your truck, trailer, and a winch. I helped a fellow move his 9n recently using a harbor freight 49$ winch.. had it off the ground and on the trailer in under 5 minutes. Back when i was working on my JB-B, while I had it partially disassembled, i needed to roll it out of the barn.. just put it in gear, and stepped ont he electric start button, and then pushed the hand clutch in a bit.. tractor moved easilly under 'starter' power. If the area is remote, you could pose as the owner, and call a flatbed tow truck to come get it as a 'broke' down unit.. etc. Any kind of fastener device.. like a chain, steel caple, etc can be cut with a shear. hacksaw, sawzall or abrasive disc.. quick... Alternately, I've not seen many things that a smoke wrench won't remove either. Removing a wheel will add inconvienience.. but if I wanted the tractor and it was unguarded.. I think I could find a wheel to bolt up with 2 lugnuts each side just to get it down the road / up on a trailer... In the end.. short of an armed 24 hr guard.. or an impenetrable concrete 'bunker'... if someone wants your stuff bad enough.. they will get it. On another board, a fellow had a roll off storage container dropped out inthe woods on his vacant 'weekend' property.. had a security cam too... crooks used a torch and cut the slid lock right out of the door.. and took vcr when they left... Soundguy
