Early 1949 8N converted to 12volt.1. Is there any way to test the alternator with it on the tractor. I know I can take it off and have it tested for free. But I think it is ok, I just want to test it. Anyway to test it using a meter. The tractor has an idiot lite on it and the light goes out when the motor starts. But I"m having to put a charger on the battery and boost it everytime I start it. I"m sure the battery is good. I"m wondering if the problem is a weak alternator. 2. Anytime I hook up the finish mower, I have to use a big hammer and beat the yoke onto the PTO shaft. Then I have to beat it back off again. Is there anything I can do about this or do I need a new yoke. I"m afraid I"m gonna break something by beating on it. I recently put a new ORC on it and that made it even tighter. 3. Can I swap the steering box out for a later one that is rebuildable. Mine works ok except for the wheel wobble in 4th gear going down the road. I don"t do that very often so for now I just use my feet to stop the wobble. Be nice to fix it rite tho. 4. Does putting rear axle seals on it help any. I don"t want to put that kind of investment in it (money and labor) of they are gonna still leak anyway. Everything looks to be in good shape except one side leaks and the other mite a little. Be nice to have steering brakes working for both sides. I"ll probably think of other questions as well. Thanks. Pooh Bear
