I was reminded of this while reading the posts and seeing the pictures of Farmer Dawn's shop. I see a small dry chem fire extinguisher hanging on the peg board. Good thing to have one. But the school of hard knocks taught me some lessons about extinguishers about 15 years ago. My son was working on an 8n in my attached garage/shop, and was draining gasoline from the gas tank into a metal drain pan, in order to service the gas shut off valve. We came close to losing the entire place, but fortunately I did the right things at the right time to save shop and house. Here is what I learned:1. Gasoline fumes are heavy and love to "flow" across concrete floors towards Kerosun heaters. 2. Kerosun heater will ignite fumes that get to it. Fire immediately "runs" back across floor to source of fumes....metal drain pan. Surface of liquid gasoline burns with intense heat and black smoke going mostly straight up. 3. Intense black smoke goes up to ceiling immediately blocking light from the electric lights. Person in shop is immediately confused by darkness and probably disoriented and may not even know where the door is...can't see anything through the black smoke as it is going from the ceiling downward to head and shoulder level. Panic sets in, person can't breathe, and will be lucky to live. 4. Fortunately, I was working just outside of the closed garage when I heard the WHOOSH and screaming. I opened the people door, was hit by an intense cloud of hot black smoke, but was able to hold breath and reach up for the electric opener button just inside the door. Being plastic, it had begun to melt from the heat, but made electrical contact and the opener began to lift the overhead door. Son was on floor, tractor was on fire, gas in drain pan was boiling and burning intensely. Automatic fire alarm was screaming and automatically calling Fire Dept. I pulled son out, fortunately no clothes on fire, and he began to move about in a very dazed manner, but got up on his feet. 5. Now to try to save the place from total destruction...and I knew that the fire dept would strongly recommend against what I did, but I felt that it was my place, and my life, and I would take the risk to see if I could save it without being too stupid. 6. I had a 5 lb dry chem extinguisher hanging by the side of the outside door, about 3 1/2 feet off the floor. Easy to find while the smoke was billowing out of the open o'head door, and I was in good air. I grabbed it, pulled the pin and began to shoot it at the drain pan, while working my way around the fire. Fire in pan extinguished, now aimed at burning part of tractor and put it out, but now pan had reignited. Still had some left in extinguisher, but was getting awful light in weight. Put out fire in pan, extinguisher now empty. Instantly located 2nd extinguisher on wall just next to inside door to house. Pulled pin and made ready to use. Gas still draining from tractor into pan. Tires very hot and might ignite. Son now able to help. We both rolled tractor outside where it flamed up again. Grabbed extinguisher and subdued the flames on tractor. Nothing burning inside of shop/garage. Now the fire chief arrived to see if he should call for the engines...I couldn't believe it... he had no fire fighting equipment with him, just his personal car. He decided that we really did have a fire, so there would be no fine for a false alarm, and he could call off the alarm for the volunteers going to the station to get the trucks, as we already had the fire out. Of course he gave me quite a lecture on fighting my own fires. 7. Lessons learned about extinguishers: a) 5 lb size is MINIMUM. b) One is not enough. Shop now has 3. c) Hang by door, no higher than door handle high. d) When the extinguisher is empty, get the hell out of there, the fire may reignite and you'll be trapped. 8. Lessons learned about fire dept: a) You don't have time to call them, especially if trying to save someone's life. My automatic system did the calling faster than I could have. b) They'll never get there fast enough to save the place, but may be able to save a nearby building. 9. Lessons learned about shop: a) Do NOT drain gas inside of shop. (I had just given son that lecture, but he was of the age where he was smarter than the old man). b) Do not have a source of ignition close to the floor, like Kerosun heater sitting on floor. c) All items on shelves in plastic containers began to melt. Plastic containers for flammables like paint thinner should be banned. Gallon jugs of paint thinner were very close to rupture, and would have made the fire impossible to fight if they had. d) Firestop (5/8") sheetrock on ceiling and walls made the difference in holding the heat away from the structure so that it didn't burn. It is not fireproof, but will buy some time before the structure is involved. Thank God there was no loss of life, and no injury. We had a mess to clean up, and a much wiser son who now asks the old man for advise instead of immediately ignoring it. We also saved the 8n and it is still running today. We have purchased 5 and 10 lb extinguishers and have mounted them by all outside doors of shop and barn. Would I recommend that anyone else do what I did? No! But we must all make what we think is the best judgement at the instant in time that it is needed. Hopefully, it is a good choice. Think about fire before it happens. Paul in MN
