2N ignition
pilot199
01-10-2006 06:43:08
Happy New Year to all.
When I finished restoring my '47 2N earlier in 2005 & hooked the ignition switch back up I found that I couldn't turn it off by the key (12VDC)! Of course turning off the fuel gets the job done but a little time consuming.
On one post the wire from the switch goes to the ammetter. On the other post, there are two wires, one goes to the ballast resistor & the other to the alternator. Does this sound correct?
Thanks,
Gary
Baton Rouge
MikeT
01-10-2006 08:27:54
 Re: 2N ignition in reply to pilot199, 01-10-2006 06:43:08
If you don't have a marker lamp, or a diode, or have P1 on the alternator hooked to an ACC terminal on the switch, then the ignition circuit will still get enough juice to keep the engine running.
DavidO
01-10-2006 08:05:34
Nice drawing, but unless you have a super duty aftermarket ignition switch, please hook the headlights to the other side. The draw of the headlights WILL burn up a standard switch.
Marty 2N IL
01-10-2006 07:01:00
third party image
You need a light or diode in the small wire coming from P1 on the alt. It is back feeding your switch keeping it running. Here is a digram with a big thanks to My Old Fords .com
pilot199
01-13-2006 11:52:16
 Re: 2N ignition in reply to Marty 2N IL, 01-10-2006 07:01:00
Marty, thaks for the schematic. Mine is basically what you have drawn there. But my alternator (12VDC) only has one lead coming out of it, there's no P1 or P2.
So what I haven't figured out yet is where is the feedback coming from. I confirmed with my VOM that the key switch is making/breaking the connection to the coil. I know it has to be something simple that I'm missing here.
Also, what size or value of diode do I need & where do I hook it up?
Also, the schematic doesn't show the external ballast resistor which my tractor has. It's attached inline on the lead to the coil.
Thanks for your help & input.
Gary Baton Rouge
