Speaking of blocks...............
Alan
04-25-2001 17:50:58
If I were to replace the block on a 1948 8n, can it be replaced with a newer model block with a side mount distibutor ????? That is, do all the bolts/lugs line up the same way. Thanks in advance.
Chris (Clawson, MI)
04-25-2001 18:39:53
 Re: Speaking of blocks............... in reply to Alan, 04-25-2001 17:50:58
The newer block will mate to the front axle and transmission, no problem. Not sure about the generator mounting bracket though. Are you installing a complete engine or just swapping the blocks?
