2N new ammeter
BTStopar
01-13-2006 09:50:46
Installin a new ammeter on my 2N, The old one was the original style shown in the book that the wire has the loop around it. The new meter has pos. & neg. poles. I have the 6 volt pos. ground system. Should my yellow wire go on the pos or neg side? Where would you run a wire from the other pole to?
LeeMo
01-13-2006 11:13:18
 Re: 2N new ammeter in reply to BTStopar, 01-13-2006 09:50:46
I just replaced an original loop style in one of my 8Ns and I just cut the wire that went through it so I could hook up either end to either terminal on the new guage and crimped on new connectors. Worked out good because it was reading backwards when I first hooked it up so I just reversed the connections to the meter. Not too tough.
Good Luck, Lee
MikeT
01-13-2006 10:02:38
Well, if you hook it up and it reads backwards, then you just reverse the leads.
