MIND OF IT'S OWN!
8-N Nut
01-18-2006 11:48:29
I have a 2n I'm working on! There is a box scraper attached to the three point hitch. The three point goes up and down at will! With control handle in up position. Any ideas, what causes this? Thanks!!!
don t.-9n180179
01-18-2006 13:31:20
 Re: MIND OF IT'S OWN! in reply to 8-N Nut, 01-18-2006 11:48:29
Someone posted something very similar a day or so ago. If I 'member right, Zane said something about crud in the pump exhaust valve.
HTH.....don t. .....
rbell
01-18-2006 12:14:17
Tell Will to get off your tractor :-)
Sorry I could not resist
K.LaRue-VA
01-18-2006 11:56:21
Sounds like the big draft control spring on the back is way out of adjustment. Take the link loose and roll it out of the way then, with the draft control lever in the up position, screw the control spring outer bracket in or out until there is just enough tension on the draft control spring to hold it in place.
If that ain't it, you might have some linkage broken or falling apart under the top cover.
Wait'll Zane wades in on this one, before you do anything.
Rick H. Ga.
01-18-2006 11:50:46
The 2N does not have position control on the hydraulic lift, only draft control.
You need a Zanethang!
HTH. Rick
64gto
03-14-2006 05:59:20
 Re: MIND OF IT'S OWN! in reply to Rick H. Ga., 01-18-2006 11:50:46
Have 9N. sounds like I desparately need Zanethang but can't find contact # or address on web site. Company address & phone # would be appreciated.
K.LaRue-VA
01-18-2006 11:59:00
Yea, but with the touch coutrol lever in the full up position wouldn't the implement stay up until you get where you are going????
Rick H. Ga.
01-18-2006 12:45:58
 Re: MIND OF IT'S OWN! in reply to K.LaRue-VA, 01-18-2006 11:59:00
I'm not sure about that. My father-in-law had a Ferguson TO-20 with only draft control and the implement would go all the way up and then back down, even with the qudrant touch lever all the way up. Of course, it could have needed adjusting also.
Rick
