To recap: The 9n hasn't been running for two to three years. I bought it off a friend so I know it was in running condition. I have basically cleaned all the old fuel out of the system and cleaned up the electrical connections. The tractor turns over and gets 6 volts up to the coil. I can't get a spark from the plugs. With the tractor I received a tuneup kit which I thought would be a good idea to install.I have read the pros and cons of converting to 12 volts. The wiring was in pretty bad shape and would have to replaced them anyway plus I live in a very cold area (Canada) and decided a 12 volt system would probably make starting the tractor a little easier. It also gets dark a little earlier in the winter up here and thought a 12 volt system could give me a little more light, etc. I intend on using the tractor for harvesting firewood from the bush.Consequently, I was hoping (with a little help from the folks here) that the new wiring, upgrade to 12 volt system and a tune up kit would go a long way in getting my baby fired up. I know the carburator was overhauled not too many years ago. As Dell suggested " Before you commit to converting to 12-volts, letts gitt yer current tractor started. " OK, I now have installed new points, condenser and plugs. Now I tried to get the tractor going. It seemed liked it wanted to start but the starter motor kicked out as soon as there appeared to be ignition. (before new plugs and points the starter would continue to turn) Flooding does not seem to be an issue. Any suggestions would be greatly appreciated. Thanks Ron
