2N hyd lift problem
Richard from SE
01-23-2006 18:05:22
Loaned my flat bed trailer to a neighbor. I needed it for a day so I went to get it with my 2N. No problem.When I went to hook it up to take it back (he still needs it for another weekend), the hydraulic lift would not even wiggle.It will not work at all!! Anyone have any idea why it would just go OUT like that???? Oil level is OK.
Richard from SE AZ
01-24-2006 20:50:18
 Re: 2N hyd lift problem in reply to Richard from SE AZ , 01-23-2006 18:05:22
All the levers were in the correct positions . Engaged and disengaded PTO lever, engaged and disengaged clutch. NADA. Works(worked)slow until it warmed up but the weather has been really nice. I'm going to look at the two things that were suggested tomorrow. Thanks
Paul K in IL
01-23-2006 18:55:09
Sorry but I have to ask and please don't take offense.
PTO engaged?
Clutch engaged?
If that is not it I would pull the side covers off, drain the fluid and look to see if the fork has come off the control valve. If you don't want to drain it you may be able to feel around in the grease and feel if it is on there. Other possible problem is relief valve stuck open.
Good luck.
Paul K.
old
01-23-2006 18:53:35
Did the PTO maybe jump out of gear on you. Seen that happen to many times and sort of funny trouble shooting a lever.
