Mulitple photos
hvw
01-25-2006 15:10:45
I know this has been addressed before but I can't seem to find an answer. Is there a way to post multiple photos, like before and after, in a single post using YT's Add a Photo. Thanks
StahlMaster
01-25-2006 18:00:39
 Re: Mulitple photos in reply to hvw, 01-25-2006 15:10:45
Like this?
Old Wiring at Generator
third party image
New Wiring at Generator
third party image
Old Wiring at Regulator
third party image
New Wiring at Regulator
third party image
lonestarjeff
01-25-2006 15:58:14
You should be able to by "tagging" each pic's Url address after you copy it(the address, not the pic)directly into the text box.
You "tag" the address by adding < img src=" in front of the address & " > on the tail of the address(no space next to the brackets).
Let's see if it works:
This should be an after pic:
third party image
This should be a progress pic:
third party image
hvw
01-25-2006 16:35:50
 Re: Mulitple photos in reply to lonestarjeff, 01-25-2006 15:58:14
Thanks Jeff. That's exactly what I want to do. I'm not computer literate but am going to try it.
hvw
01-25-2006 16:47:54
 Re: Mulitple photos in reply to hvw, 01-25-2006 16:35:50
Before
third party imageLink loading="auto" style="width:auto;height:auto">">Link
During
lonestarjeff
01-25-2006 17:05:24
 Re: Mulitple photos in reply to hvw, 01-25-2006 16:47:54
Looking good. Are those front tires old military tires? I like 'em.
Jeff
hvw
01-25-2006 18:02:24
 Re: Mulitple photos in reply to lonestarjeff, 01-25-2006 17:05:24
They are. The good things about them are they positively won't tear up the grass and they wear like iron. The bad thing is they're a little ugly.
I sold this tractor to a friend a little over twenty years ago in original condition. Even had most of the original decals in place. The leather ball joint seals, etc. He put the front tires on it and tried to use it in his construction business but it just wasn't beefy enough. So he let it sit outside for 15-18 years.
Called me about two years ago and said I could come get it if I wanted it back otherwise he was going to have to haul it off. Even had a tree growing through it. Since then we've made it a good tractor once again but it's no longer original.
hvw
01-25-2006 17:53:19
They are. The good things about them are they positively won't tear up the grass nd they wear like iron. The bad thing is they're a little ugly. Thanks again.
hvw
01-25-2006 16:49:46
I did it! Thanks from a computer idiot Jeff.
