Order Ford 9N Parts Online
9n oil pick up tube loose?
apetroski(OH)
01-29-2000 11:12:58
Hi all, After bringing home my first 9n, I started to go down the list of things to check.(this lists archives have been a BIG help) A rebuild will be in the works but things are running well(some oil burning). When changing the engine oil I found that the oil pickup tube was a little loose. I can move it up/down from the drain hole an inch or so. Is that normal or do I have some loose parts. I've been pushing some snow around and have one heck of a clean driveway. Thanks
Dave (PA)
01-29-2000 11:28:05
 Re: 9n oil pick up tube loose? in reply to apetroski(OH), 01-29-2000 11:12:58
I just got done replacing my oil pickup tube. It broke off and got picked up by the crank. That's a bad thing. You should definitely fix it asap. There's already very little clearance between the pickup tube and the crank. An inch play at the drain hole is probably more than enough to cause a collision. Just my opinion and experience.
Phil(NJ)
01-29-2000 12:09:38
 Re: Re: 9n oil pick up tube loose? in reply to Dave (PA), 01-29-2000 11:28:05
Dave, What is the correct Part # for the Pickup tube assembly 9N? and is it a "one piece". I tried to Solder mine, tight but?? would seem better if welded.
thanks,
Dave (PA)
01-29-2000 12:39:21
 Re: Re: Re: 9n oil pick up tube loose? in reply to Phil(NJ), 01-29-2000 12:09:38
I'm not sure of the correct part number. I ended up getting one via the YT classifieds. I'm sure someone here will chime in with the part no.
Ringy
01-29-2000 13:38:45
 Re: Re: Re: Re: 9n oil pick up tube loose? in reply to Dave (PA), 01-29-2000 12:39:21
The part # is 9N 6615
