oil in radiator
Peter Hall
01-30-2006 04:09:36
How can oil get into the cooling system on the 8n?
ZANE
01-30-2006 11:08:49
 Re: oil in radiator in reply to Peter Hall, 01-30-2006 04:09:36
Click on the link below in the archives. This has been visited many times in the past posts/
Zane
Carl S in NH
01-30-2006 12:26:00
 Re: link no good in reply to ZANE, 01-30-2006 11:08:49
Zane,
Your link only brings me to the search box, not to a results page. Perhaps you can find the discussion and copy/paste the addy again?
I entered your words "oil in radiator" and found several good discussions. Below is a link to one of them.
Carl
souNdguy
01-30-2006 04:38:17
Well.. Oil could get in thru a cracked block. Whoever.. lots of people have bad heads / head gaskets and that lets in combustion byproducts over the years, and those will form an oily sheen on the water too...
If you have a bit of oily crud int he water.. but no water in the oil.. that's when you change the head gasket and 'watch' it. if you atre getting water into the oil.. you may wnat to investigate faster and pressure test the cooling system.. etc..
Soundguy
