Bad knees
ronjoh
01-30-2006 14:29:08
I really have been having a tough time getting on and off my 9N because of bad knees. I think knee replacement may not be too far off.
Has anyone seen plans for a running board or similar item that I could attach to my tractor?
Thanks
Ron
souNdguy
01-31-2006 05:04:51
 Re: Bad knees in reply to ronjoh, 01-30-2006 14:29:08
2 options.. Get a set of boards that hang on the foot pegs, or modify a set of 8n boards. The 8n boards will attach wher ethe foot peg cap is.. then you just have to finagle the back bracket a little.
Soundguy
Dixon
01-30-2006 22:19:31
Allright alright-The Marines have to jump in here to.So bite the bullet and get those knees fixed,I got one it took me about three months to be normal but my nieghbor got down to 5"3" then both replaced and was out with his tiller in two weeks and stood 5"7" big differance.would I go thru the pain of not doing it again nope like the guy on TV Get er Done.You"ll write and thank me I"ll bet and you"ll be able to mount yer N form behind if you know what I mean like whoopalong cassidy.
cman
01-30-2006 15:56:32
Ron,
Check out this web sitehttp://www.tntwebdevelopment.com/tff/nformation.htm
They show running boards
Cman, in North Carolina
TennesseeMan
01-30-2006 15:49:43
I feel your pain. I"m 52 years old with bad knees. I spent 20 years in the U.S. Air Force working on Jet Fighters. The cause of my knee problems is from kneeling on the cold pavement while working on the flightline. For you younger people, take care of yourself and remember the body will wear out.
DON TX
01-30-2006 16:48:58
 Re: Bad knees in reply to TennesseeMan, 01-30-2006 15:49:43
I spent 3 years on the flightline (F4s). Almost done my knees in, too. Used the tech manual when possible for knee pads, if it didn't raise ya up too high. I don't miss it at all. Of course, now there are other issues,...hearing, eyes, joints...etc..Later,
DON TX
TennesseeMan
01-30-2006 18:50:18
 Re: Bad knees in reply to DON TX, 01-30-2006 16:48:58
I spent 7 1/2 years on the F-4D's. I feel your pain and the Phantom bites you received. I do have to admit, I miss them birds.
DON TX
01-30-2006 20:48:46
 Re: Bad knees in reply to TennesseeMan, 01-30-2006 18:50:18
I do miss the power they had in dual afterburner, accidental of course (%^), tied on the trim pad at night. RF4C Bergstrom, F4D Kunsan. 77-81 DON TX
TennesseeMan
01-31-2006 03:21:21
 Re: Bad knees in reply to DON TX, 01-30-2006 20:48:46
I did the same thing one sunday morning at RAF Lakenheath, I was tied down on the trim pad and I was not gonna pass up the opportunity to move both throttles up to max A.B. Man my knees were shaking when I climbed down out of the cockpit acft 66-243. Remember how they could tell that you went above 80 or 85%? The engines started to howl. Gotta love them Phantoms. But they did work a poor Crew Chief to death. "Hey gotta fuel leak, please remove panel 48"
DON TX
01-31-2006 17:25:16
 Re: Bad knees in reply to TennesseeMan, 01-31-2006 03:21:21
I was under the a/b when the guy running the engines told me over the headset, "WATCH THIS!!"..... WOW!!! Could look at the rear rotor section of the engine and see the stationary blades thru the white hot skin with the bay doors down. Two cones of blue flame shooting 20 - 30 ft. out. Still fresh on my mind. I was walking on air for the next hour. I got my run license later, never got the opportunity to return the favor. The cockpit run gave you a good idea of the power involved. That was the place to be if possible. Enuff remenicing. Later.
DON TX
old
01-30-2006 15:11:36
My 9N has running boards, they hook to the foot pegs up front and in the back they bolt to the rear end houseing. Also value----- ---bilt has running boards for 9 and 2Ns.
