Washers
RussMO
02-02-2006 12:22:04
Received new head and gasket today and gave it a shot of GRAY paint before installation.
I have been looking in the archives for an hour and still need to ask. Should I use washers on the bolts and/or studs. There were some on previously.(could have been part of problem?)
Thanks
K.LaRue-VA
02-02-2006 18:38:31
 Re: Washers in reply to RussMO, 02-02-2006 12:22:04
I like grade 8 flat washers for grade 8 bolts, but the manual does not have any washers so it's your tractor, your call. Id also put a little of my favorite sealant on the bottom threads of any head studs that came out or even better replace the studs with new ones with a dab of permatex on the threads.
Bruce (VA)
02-02-2006 12:54:43
No to lock washers. Why grey paint? I've heard of using aluminium paint, but not grey paint.....
RussMO
02-02-2006 13:51:51
 Re: Washers in reply to Bruce (VA), 02-02-2006 12:54:43
Top side with gray paint, nothing on bottom.
dbwillia
02-02-2006 13:06:12
I suspect he is talking about painting the top of the head, and not the gasket side, with gray paint.
TheOldHokie
02-02-2006 12:29:12
Too much torque for lockwashers - they'll open up. Plain grade 8 bolts or a flat washer if you want.
TOH
