polorizing generator
perk
02-02-2006 12:33:38
How do I polorize the generator on my 2N? I have a 47 2N with 6v, positive ground and a cut-out can. I have been on the archives trying to figure it out but it is still not clear in my mind. It seems they are talking more about 8N's and relays. I was thinking that somewhere I read that all I need to do is short the two terminals on the cutout. Just want to be sure, b4 I blow up something.
Thanks in advance
dan hill
02-06-2006 04:18:52
 Re: polorizing generator in reply to perk, 02-02-2006 12:33:38
This polarizing bit is not needed.Kind of like teaching a dog to bark.
Bruce (VA)
02-02-2006 12:52:01
Yea, you got it right. Use long handle pliers & jump the cut out.
perk
02-02-2006 15:10:26
 Re: polorizing generator in reply to Bruce (VA), 02-02-2006 12:52:01
Thanks Bruce..... ..Just one more question. Do I do this with Sw on or motor running??
DavidO
02-02-2006 16:06:22
 Re: polorizing generator in reply to perk, 02-02-2006 15:10:26
Switch On, Motor NOT running.
souNdguy
02-02-2006 19:42:49
 Re: polorizing generator in reply to DavidO, 02-02-2006 16:06:22
Think about it.. sw on OR off makes absolutely -0- difference. sw just controlls current flow to ignition coil.. don't have a thing to do with the charging system...
Soundguy
DavidO
02-03-2006 04:41:21
 Re: polorizing generator in reply to souNdguy, 02-02-2006 19:42:49
You are right again SouNdguy. On the tractor, the relay is connected directly to the battery and does not go through the ignition switch. I guess I am just too accustomed to working on cars where pretty much everything gets power via the ignition switch. Anyway, it won't hurt if he does it with the key on.
souNdguy
02-03-2006 07:28:55
 Re: polorizing generator in reply to DavidO, 02-03-2006 04:41:21
Not a bit, as the key is out of the loop so to speak.
Soundguy
perk
02-02-2006 16:28:34
Thanks, DavidO. Now I can apply this tomorrow!
