Shift lever spring replacement
Tjet
02-06-2006 10:38:06
Does anyone know of any good tricks to replace the shift lever spring and clip thats under the shift cover plate. My spring broke in half and needs replacement
Willy-N
02-06-2006 18:38:15
 Re: Shift lever spring replacement in reply to Tjet, 02-06-2006 10:38:06
third party image
You have to pull the cover off. You also remove the saftey switch. Now going by memory but when you push down on the shifter and on the bottom side if you look up you will see a pin that goes thru the ball area and you need to remove it. There is a chance this pin is on the top side to. Then it should come apart on yo. When you have the cover off and cleaned up you can see it. Here is a picture. You will be able to figure it out when you see it but the pin slips out pretty easy once you see it. Mark H.
Willy-N
02-06-2006 18:43:39
 Re: Shift lever spring another view in reply to Willy-N, 02-06-2006 18:38:15
third party image
You can see better in this picture. Mark H.
Willy-N
02-06-2006 19:03:46
 Re: Shift lever Pin Picture in reply to Willy-N, 02-06-2006 18:43:39
third party image
It was on the top!! You drive this pin out to remove the shifting arm. Mark H.
tjet
02-07-2006 04:47:31
 Re: Shift lever Pin Picture in reply to Willy-N, 02-06-2006 19:03:46
I do understand hoe to disassemeble it. I have taken it apart to remove the old broken spring. I have to install the new one and it given me trouble because it needs to be compressed in order get it onto the shaft. Also inserting the keeper clip under the spring is given me trouble. ANY HINTS ON HOW TO INSTALL THE SPRING AND CLIP WITHOUT BUSTING FINGERS? tHANKS
Willy-N
02-07-2006 06:48:48
 Re: Shift lever Pin Picture in reply to tjet, 02-07-2006 04:47:31
Keep tring it is tight to get it back together! Been a couple years since I took one apart to clean. Mark H.
Tjet
02-07-2006 07:25:24
 Re: Shift lever Pin Picture in reply to Willy-N, 02-07-2006 06:48:48
Thanks. I havent spent alot of trying to install it yet. I went to a reputable Tractor parts place and they told me you cant do it without grinding the rivets off the bracket that holds the whole assembly. They want to sell me the whole shifter assembly. Big $$$$. Have you actually rfeplaced this spring before?
Thanks
Willy-N
02-07-2006 21:27:01
 Re: Shift lever Pin Picture in reply to Tjet, 02-07-2006 07:25:24
Never replaced the spring befor but took it all apart to clean one then put it back together. Mark H.
K.LaRue-VA
02-06-2006 17:28:39
I looked in all my manuals and there was no help there either. Looks like you have to just pull the top cover and start taking it apart.
