governor repair
8N'r
02-07-2006 16:23:59
Need to replace the driveshaft in the governor assembly. After removing the linkage and the 2 gov. housing bolts, will I need any tools other than a screwdriver to remove the assembly and replace the driveshaft? Thanks for the help.
John (TR)
02-07-2006 17:38:47
 Re: governor repair in reply to 8N'r, 02-07-2006 16:23:59
If you are replacing the main shaft that is in the gov you will find that the front gear is pressed on. I ususally set stuff like that on my big bench vice and drive the shaft out with a brass hammer/brass drift.
I've rebuilt 2 governors and both of them when the gear comes off I founds small divits in the shaft. The new shafts were too loose with the old drive gear (for a press fit) and I used an old machinist trick and used a center punch and punched a number of new divits into the shaft equally spaced around the shaft and pressed the gear back on. Look at the IT manual and there is a measurement from like the back of the plate with 4 holes and a keeper on the shaft, it's in the neighborhood of a quarter inch. The one I took apart that would never work (govern) was not even close. Don't know how it got that way but it probably did not need rebuilding. I rebuilt it and set the distance exact and it works like a champ.
CT8n
02-07-2006 18:08:47
 Re: governor repair in reply to John (TR), 02-07-2006 17:38:47
Also check the bushings on the 2 levers that connect to the carburetor and the throttle. I figured out that I should have replaced those bushings after I rebuilt mine.
