Identification?
8N'r
02-11-2006 14:18:20
I have a 51 8N. About 6 inches to left of the Timing Hole and below the air cleaner there is a small screw in the housing. It appears there is a rubber washer/grommet next to the metal followed by 2 or 3 metal washers held by this screw. Does this screw serve any useful purpose or did somebody just plug a hole up in my housing? Thanks
souNdguy
02-11-2006 21:11:14
 Re: Identification? in reply to 8N'r, 02-11-2006 14:18:20
Post a pic.. could it be a hole for a cable operated sherman? or other aux tranny that may have used that side for a shifter hole?
Soundguy
8N'r
02-12-2006 03:56:01
 Re: Identification? in reply to souNdguy, 02-11-2006 21:11:14
I will get take a pic next weekend and see if I can get it posted---thanks
Jim.UT
02-11-2006 19:11:21
I'm not clear on the location of the hole you're talking about. Is it in the clutch housing? If so, it may be that someone used the tOTG method of unsticking a stuck clutch. John Bower, aka "the Old Tractor Guy" (tOTG) posted about a month ago giving a method to fix a stuck clutch. I just spent 20 minutes trying to find the post in the archives and came up dry.
Basically the procedure involved drilling a hole so that one could spray brake cleaner on the clutch to get it free up. Then he advocated tapping the hole to accept a threaded machine screw. Then it could be used again if the clutch got stuck again.
8N'r
02-12-2006 04:18:55
 Re: Identification? in reply to Jim.UT, 02-11-2006 19:11:21
Jim--the hole is in the clutch housing about 2-3 inches from the point where you would break the tractor to replace a clutch. I remember seeing the post on the OTG method of unfreezing and will look for it. I would guess the hole that was drilled is less than 1/4". If it does not leak, do I need to be concerned with this for any reason, or should I think of it as another way of giving my 8N some "uniqueness"? Thanks
