machine shop report - advice?
FarmerDawn
02-13-2006 17:01:34
I went to the machine shop in Scottsbluff today where the man had said they do a lot of old tractors. His name turns out to be Brian, and he is a fairly young guy (younger than I am, maybe mid-40's?). He wrote out prices for me and we talked a while, and I made notes. I thought if I told you about it, some of you might tell me what you think -- whether this sounds like a good shop to use or whether I should go look in Lusk, WY and in Chadron and maybe Alliance (all within an hour or two drive). So here goes.
First, Brian knows a lot about 8Ns. He asked me things like if it was the type with the .090 sleeves or not, things like that, and was clearly real familiar with them and their specs. When I said that the valve guides were one-piece, he casually said, "Well, they just don't make the two-piece guides any more anyway; they're obsolete. So you put in a one-piece no matter." He wasn't being critical or anything, he was just knowledgeable about it and telling me it wasn't a big deal. He said things like the block surface hardly ever needs to be resurfaced, but the head often does because it's thinner so it warps more frequently.
There was a gorgeous '68 Mustang in the shop that he had just put a 471 engine and a manual transmission in. He said (related to a different conversation) that he does a lot of race cars where he puts in parts that "weren't meant to be in there originally" and so he "just works things on the machines so they'll fit and work well."
He said that it's ok for me to be there to watch how he does it when he magnafluxes the block and stuff. He seemed to think it was a little odd I wanted to see what it was like, but it wasn't a problem to him.
He prefers to buy the parts himself. He charges an additional 20% for labor if a customer buys their own parts. He gets parts from a place called Endurance, and he says he only gets new parts, never rebuilt. (This is how the race car thing came up, is I asked if what I had heard was true, that sometimes the new parts aren't quite made right and they don't fit well. He was explaining that he can get them to work, although it's generally not a problem.)
Here is the price list he gave me (not all of it, but enough to give you an idea):
clean and check head -- $40
resurface head -- $45
clean block -- $150 (he bakes it in a special, very hot oven and then dips it; I don't have to do anything to it first, like remove paint)
flux block -- $40
grind valves and seats -- $105
check rods -- $5 per rod
resize rods -- $10 per rod
getting out the broken head bolts -- $25 per bolt
What do you guys think? Have I found a good shop, or is he too expensive, or should I find one that uses different parts? I know I will have to make the final decision, but I would appreciate your input since you ALL have so much more experience than I do in selecting and using a machine shop (since I have NONE! LOL).
Dawn
JimNC
02-14-2006 15:07:54
 Re: machine shop report - advice? in reply to FarmerDawn, 02-13-2006 17:01:34
FarmerDawn,
With all the work you have done to Arty so far there is no need for you to farm out all the work. You can clean the block inside and out yourself ($150 saved). I am pretty sure you can get those broken bolts/studs out, I"m sure all of us here can say you can. Whatsa that?, another $50-$75 saved. I"m also going with most the others in saying "get a second opinion". Don"t be taken by the good looks and smilin" faces they can rip ya off too. And like Hobo said don"t tell them you ain"t in no hurry. But also don"t say you need it yesterday.
Jim
TheOldHokie
02-14-2006 12:54:35
Well Dawn you wouldn't want to "watch" him clean the block in any event. Job goes something like this:
1) Block is completely disassembled, expansion plugs, oil gallery plugs, sleeves, etc. removed.
2) Machinists's helper (minimum wage) submerges block in a vat of caustic liquid heated to about 200F.
3) Machinist and helper go home to bed.
4) Two days later helper fishes block out of tank and hoses it down with clean water.
5) Helper loads block into shot blast cabinet and proceeds to scour exterior and interior with a hail of compressed air propelled shot.
6) Helper removes block from cabinet and blows high pressure compressed air through all internal passages and cavities. Washes block with soapy water.
7) Block is now ready for the attention of the machinist ;-)
And just as a data point when you start collecting estimates a NEW short block including new pistons, rings, crank, valves, lifters, etc can be purchased outright for $2600. A factory remanufactured short blcok from the same source is $2100. But then what fun is that ;-)
TOH
hvw
02-14-2006 17:16:01
 Re: What a lot of good feedback!! in reply to FarmerDawn, 02-14-2006 12:06:35
Now Dawn, even if the price was fair and I guess I was the only one who thought it was okay, I wouldn't pay someone to fix my N if he thought it was junk. He won't have his heart in it. I'd go somewhere else like all the other folks suggested. Remember also when you go see these guys that you represent a one time customer to them so you probably can't expect the machinist to cut you a "great" deal like he would for a repeat customer.
FarmerDawn
02-14-2006 17:40:31
 Re: What a lot of good feedback!! in reply to hvw, 02-14-2006 17:16:01
Those are really good points, and actually I thought the prices for some of it were ok. The thing is, usually prices in this part of the country run lower than they do in cities. So I was surprised at some of them. Now just watch -- I'll go get estimates and find out that's the going rate around here! LOL But you're right that the key issue is one I never mentioned and didn't even really think about until after I read all your responses, and that's the one about him thinking Ns are junk. What you say about repeat vs. one-time customer is a good point, too. I hadn't thought of that at all, and I know it's got to matter. Thank you!
Russ SoCal
02-14-2006 21:44:32
 Suspicious is good in reply to FarmerDawn, 02-14-2006 17:40:31
And I'd be suspicious of any machinist younger than I. And "I" is five or four years older than "Thy."
Russ
FarmerDawn
02-15-2006 04:48:38
 Re: Suspicious is good in reply to Russ SoCal, 02-14-2006 21:44:32
LOL!! Well, then I'll bear THAT in mind, too! LOL!!
Vern-MI
02-14-2006 11:54:26
Did you ask if you could watch before or after he gave you those prices?
TheOldHokie
02-14-2006 10:33:04
My first impression is that some of the charges are about right and some seem pretty high. For example the $40 to magnaflux the block is OK but $150 to cook the block is about 3-4X what I usually pay. On the other hand if that includes R&R of sleeves it's getting closer to reason. If I'd been given those prices I'd definitly be shopping it around a bit.
One approach is to simply ask for a total price for a complete short block rebuild and a list of what work and parts are included in that price. With most shops piece work prices are often way more than a package job.
HTH,
TOH
TheOldHokie
02-14-2006 10:39:00
 Re: machine shop report - advice? in reply to TheOldHokie, 02-14-2006 10:33:04
BTW, I forgot to mention that a running joke at most shops is rates are double if you watch and triple if you help ;-)
TOH
Denton Fender
02-14-2006 09:48:26
Dawn, I just a local machine shop in Fort Collins do my 8N engine. I don't have the breakout at this writing, but to go completely through the engine, e.g. clean, flux, replace sleeves, grind crank, resurface head, valve seats, recondition the rods, replace piston wrist pins, resurface flywheel, install repair sleeve on crank pulley and few other minor details, all came to $460.00 labor. I furnished the valve train pieces and this price included installing and adjusting the valves (original style). He supplied all the other engine parts but they were only about $35 more than what I could buy them for online. By the time shipping was factored in, the cost was about the same but the quality in the end was much better. I think the parts he furnished came to around $325
Joel -Tex.
02-14-2006 08:57:21
Dawn,
If I remember right you are a ways from somewhere. LOL. If your guy is the only game in town he can do or charge what he wants with in reason. If you look at the tool kit that came with tractors, and remember that most of the owners were use to looking at the backside on a mule you know it was made easy to work on. Most of these guys thought baling wire and pliers were high tech. What I’m saying is tolerances are not real close but still important. I have worked on many space programs, tolerance is important but most of the close tolerances were to control weight. (the 747 has over a million parts you add ¼ oz. to each one you have an extra 15,000lbs.)
Everything you have been told is good. I would want to talk to someone he has done work for. I would also want to check other places out as well. I would want to see his shop if the work area is clean and how he takes care of his precision tools. If his precision measuring tools on the bench with stuff on top of them LEAVE.
My 2 cents
Rick H. Ga.
02-14-2006 07:33:32
I've only dealt with a machine shop a few times in my lifetime. Once with my 8N engine rebuild and once with my 53 Jubilee engine rebuild. I will admit the prices you listed seem a little high and, as others have said, some of the services on your list may not be absolutely necessary (such as shaving the head and heat treating/cleaning the block). What happened to old fashioned acid vat block cleaning? Also, as others have said, the guy did not even give you his prices for the most important services like grinding the crank shaft and replacing the sleeves. What about fitting the pistons to the bore cylinders/sleeves or assembling the engine (fitting the new pistons to the rods) or rebuilding the oil pump? If you buy a new oil pump, the main bearing cap will need to be align bored.
On the other hand, professional machine shop mechanics provide a highly skilled service and their work is not cheap.
If I were you, Dawn, I would at least get other bids/prices on your project Arthur. Write up a list of the exact services you want and go from there.
HTH. Rick
Tim...Ok
02-14-2006 03:47:42
Sounds too expensive to me..at least on some of it..keep shopping..
JohnMD
02-14-2006 03:43:12
Just to compare. My neighbor purchased a completely rebuilt engine from one of the on line tractor parts places last summer for $1,400. They had a special on that gave free shipping. It runs good and holds 30 lbs oil pressure in the summer with 30W oil. Cyclinders read around 115 lbs each. We did all the work in the back yard under a shade tree. It was not cheap but if you figure up parts and shop labor and it comes up near $1,400 you may want to look some place else.
Russ SoCal
02-13-2006 21:08:23
Dawn, You need a second opinion. Some of what he says is fair, some is unnecessary BS. He has it over $500 and hasn't mentioned sleeves, pistons or crankshaft.
I'm not familiar with "Endurance" but it sounds like a place for Mustang parts, not tractors.
That shop may be your best deal because there aren't that many games in town. However, Arthur deserves taking the time to find out if you're getting taken to the cleaners.
Russ
Dan
02-13-2006 19:54:05
Well, I can only give you my experience. I knew almost instantly I found the right machinist after 5 minutes of conversation - and I was picky. I could tell the guy was a professional almost right off the bat, and he even admitted up front he did not have much experience in old tractor engines - but he specialized in old car engines that shared a lot of common ground and theories. I knew up front I wanted to put the new parts on, I just needed a good machine shop to get the engine ready to put the parts in it. Once I got it back, it was really a breeze to install the parts into the engine, and you may very well be able to do this as well.
Now, this is on a NAA engine, so some of the things I got done will not apply to your 8N - plus I had some nasty corrosion on the surface of the block that had to be fixed. Also, he did not break every item out individually, but does have each item listed out. Here is what I paid: Deck block - $70, surface flywheel (you will not need this probably) - $38, Remove/Replace valve guides and hone to size, Magna-Flux block and head, Vat and wash block (actually 2 dips and 3 pressure wash cycles - it was bad), Install freeze plugs, Remove/Replace sleeves and Plateau hone, R&R pistons on rods, size rods, Install piston rings and size, R&R rod pin bushings and hone to size, Valve job, Mill head surface (you do not really want to do this probably), Crankshaft polish and camfer oil holes - $750. Now, he removed and replaced my supplied starter ring on the flywheel, drilled out a bolt that I snapped a EZ-Out in, and helicoiled the hole back to the original size, new rod nuts, sleeved the valve guides, three freeze plugs, coated and sealed the engine block - FREE. All said and done it was $858, I bought a $350 FULL complete rebuild kit and gave the machine shop the rod bushings, piston rings, sleeves, pistons, valves and guides, and maybe a few other items, then I just put it all back together at home.
I had to spend a little more than normal because of the condition of my engine, but he did an EXCELLENT job and when I double checked his work with plastiguage it was dead on. He found the specs for clearances himself, and could also get the rebuild kit if I needed him to. He worked out of his shop behind his house, so was not eager to have me drop by and "watch" - some guys are just like that.
Maybe your machinist does not want to get crap parts that he will be liable for, but charging 20% for you to provide quality parts seems out of line. Bottom line - your gut will usually tell you if this shop is the one - what does your gut tell you?
Good luck,
Dan
K.LaRue-VA
02-13-2006 19:16:03
Prices seem high to me but thats not surprising as its been about 15 years since I had any machine shop work done and that was on Chevy V8s.
One thing not mentioned in your prices was a break for bringing the parts in already dissassembled. The shop I used to use had VERY different pricing for people who just brought in a set of heads or a bare block to be reworked. It saves them a BUNCH of labor if you do most of the wrench turning yourself, so it should have been mentioned in the prices he quoted.
The guy with the "68 stang should be paying on a totally different scale than you since it sounds like they are doing a turn-key job on that one, and there is a HUGE difference in the amount of precision necessary for your tractor motor.
nimster
02-13-2006 19:05:50
Hi Dawn! I'd suggest you talk to someone who lives in your area and has an 2, 8 or 9N and (although it doesn't happen often) may have had it repaired. You mentioned someone whom you had given your loader to and that person might be able to give you some good inside information("lived here forty years and I always took my Ford to....") Or that person might know of someone. I'm a visual learner. If I see it done once, I can usually figure it out. Vocabulary is about 60% of the job.
Hang in there!
Jack
TIMW(PA)
02-13-2006 18:59:01
Dawn. after looking into baking my enigne and talking to a machinist friend of mine I decided not to go that route. For any other engine I wouldn't have any concerns, but I was worried about the cam shaft bearings. In this engine there are no bearing inserts they are actually milled right into the block.. I didnt want to run the risk of any oxidation or miniscule warping goin on there. Now that is just my two cents, and others say its ok. I cleaned mine up with a 90 degree die grinder with a wire brush cup. knocked the freeze plugs out and took the whole thing down to the car wash and power washed it inside and out. coated it immediatly with a can of WD-40. Blew it out good at home with more air and a good coating of oil and grease on the cams and it looked great. plus it cost me less than ten bucks and some elbow grease. So like I said everyone says its ok to bake it I was just worried about it....
Hobo,NC
02-13-2006 18:38:25
Look fer a nutter shop, you do not need the head resurfaced. I sort of don"t like to deal with a shop that has a race car ( seen to many go belly up try"in to feed a race car, you know who pays fer the race car, YOU) I also don"t like to judge a nutter mans price if he kin git it more power to"em a good mechanic should git all he kin. I don"t see a price fer the rebuild only machine werk. You also need a price to grind the crank. Also no resurfacing of the block. I do like the shake and bake set up and worth maybe 100 to clean the block and head. Theirs only 1 machine shop around here all the rest closed up. A parts store does a little werk but haft a$$ werk. they git $60.00 to clean all the engine parts but mite as well throw the money down a well cuzz parts never come back clean. They tell me they need to change out the clean"in fluid so they charge to clean knowing its not cleaned and wonder why they have nuttin to do. I would luv to have all the valve werk I could git at “grind valves and seats” -- $105, does that include reassembly of the valves.. Also may pay ya to mark yer head sum were just in case it comes up bad you kin Identify it. I have a reputation of not let’in junk set around my shop long, (tractors are not junk) I will git rid of it I ain’t the keeper of utter peoples junk. When you decide to go with the engine werk be ready to pay fer it or they may be like me and if it set around to long sell it for their labor and parts. Sum times its bad to say I’m in no hurry take yer time, that will give’em a excuse to put yer werk off. Best to say as soon as you kin werk it in, when do you think that will be, git a answer to that. I helped Jim, NC reassemble hiz engine and the hold up wuz git’em the block lined bored. Think it took’em 6 mo. to git"it done they slowed played it to death. Sum how the main caps got lost. Also git a price on parts theirs nuttin wrong with the 20% mark up on labor at least he told ya up front. I sell a lot of engine parts and once in a while run into a builder who finds sum’in wrong with the parts and its their way of try’in to git the buyer fired up cuzz they are pi$$ed the customer brought their own parts. Always find when I call’em they think I am questing their ability to do the werk so I try and not git into that and tell’em up front charge’em for the werk what ya think you should all I am interested in izz what’s do we need to do to git it right. Once they see I am will’in to help and not look’in to blame enny one we werk it out. This has happen on the free rotat’in exhaust valves were they just don’t want to take the time to set’em up so the EZ out izz to say them valves are junk. I also turn down a lot of werk were the customer supplys their own parts sum times it to aggravating to try and use their parts. But if it comes down to it its no problem cuzz if your part does not fit or for sum reason it holds up the job you pay the whole time yer car sits on my rack while I wait fer you to git the rite part and no warranty what’s so ever in write’in.
Joe (IN)
02-13-2006 18:07:07
Well, I'll point out a couple quick things. First, his knowledge of N's is obvious and apparently for real, so that's a definite plus. However, an intimate knowledge of the intricacies of your particular engine isn't necessarily the mark of the ideal machinist. A good machinist just needs the proper specs for the engine and parts he's working on. Beyond that the parts in one are the same as in any other. Only wanting to use his parts is a red flag in my opinion. As long as you go with a brand name, parts is parts. Unless you get the cheapest off brand junk you can scrounge up, what he gets will be no better than what you will. They will require the same prep and measurment regardless of the brand name. Remember: you are working on a low compression, low speed engine in a tractor that you will doubtfully ever work near as hard as it was built to. You don't need race car quality parts to get the life and durability out of it that you want. He's trying to sell parts - at a healthy markup. He'll tell you whatever he has to to convince you that his are better. Charging you for carrying in your own is plain ludicrous. He's only compensating for losing the markup on the parts. The only thing he wil need is the pistons and the sleeves anyhow. Everything else is essentially the responsibility of the engine assembler to fit or check anyway. As for the prices, the first thing that jumped out at me was the head work. He wants $85 total to clean, inspect, and resurface the head. A brand spanking new head is only $140. Resurfacing an N head is rarely a good idea anyway. Even if they are slightly warped, they will pull flat and seal just fine when torqued anyway. There is very little material on these heads to be removed. One cut in the head's lifetime is about the max. If it's already been cut once and he does it again, you may have valve or piston interference problems which will force you to replace it - after you paid him to work it over. You'd be money ahead to clean it yourself with a wire wheel and check it with a straight edge and feeler guage. We can tell you how to do that for free. Around here, $150 is sky high for cleaning the block. By about a factor of two. The other prices don't seem too far out of reason. You didn't mention getting the crank cleaned, checked and remachined. The crankshaft and the associated bearings are THE ONE most important part of machining and rebuilding an engine. They govern longevity and oil pressure. The rings, pistons, and cylinder walls (sleeves) are a close second. Keep that in mind. Overall, I'd say keep looking. He sounds knowledgable and would likely do a fine job, but I think in the long run you'll be paying dearly for it. There are probably better deals.
dan hill
02-14-2006 02:27:35
 Re: machine shop report - advice? in reply to Joe (IN), 02-13-2006 18:07:07
A machinist and and a mechanic are two different animals.I can operate basic machine tools but that dosent make me a good machinist.A modern CNC machinist would be lost on an 8n engine overhaul.You can get skinned badly in some shops.A ford tractor dealer who has been in business for a long time should be consulted.Do they do inshop overhauls or farm out these jobs?You may get a better deal on a short block overhaul.A friend had a diesel tractor that was hard starting,even in warm weather.This usually means worn rings ,low compression.Took it to a local dealer for repair.Cost 1800.00,didnt act any better.I noticed oil pressure was low and dropped even lower when warmed up.Two years later a tech school teacher was looking for a diesel engine project for the school.He found no new bearings or rings in the engine.The tractor got little use in two years.An AC WC tractor was used to get his hay in the 2 years his diesel rarely started.When the diesel came back from the school the tractor started fine.His only cost was for parts.
Bevo916
02-13-2006 18:03:13
I just had some machine work for an 8n from a local NAPA shop, Here is what they charged. I hope this helps.
Resurface Head and Block: $ 85.00
Replace valves and valve job: $60.00
Install sleeves,cam,rebuild oil pump, and crank shaft: $50.00
Flux block & head $25.00
Power cylinder hone: $30.00
Jet hot clean head and block $65.00
Hazardous waste disposal $15.00
Grind crank .10 under: $125.00
New expansion plugs and installed $1.44
Complete engine kit $376.00
Tim...Ok
02-14-2006 08:05:37
 Re: machine shop report - advice? in reply to Bevo916, 02-13-2006 18:03:13
Bevo's prices above from his napa are more inline with what I expect and usually pay..too high on the crank turn,but they send that out to someone else to do,so they gotta make something off it..if the shop grinds their own cranks,(most don't) it should be more like $70-90..
HTH,
TIm
hvw
02-13-2006 17:28:09
I am by no means an expert on machine shop rates. But from what you've stated it looks like he's going to charge you a little better than $500.00 in labor plus parts to rebuild your engine as a long block. Probably around $1,000.00. That's not including any unforseen problems like a cracked block and so forth.
You'll have to rebuild the carburetor and govenor, if necessary, replace the water pump, etc. His price seems consistent with or a little less than what you'd pay to a good machinist around these parts.
You mainly want a good machinist rather than just cheap so you won't be doing a repeat. You might check some of Dan's old post to see what he paid for rustbucket's machine work. I think he was well satisfied. Altogether, it doesn't sound bad to me.
old
02-13-2006 17:27:04
Some of that sounds way off to me. Most shops in my area do the hot tank for the block as part of the sleeve and in your case valve job. Lat engine I did from the bottom up which included all you said there cost me less then $800 and that included all the parts. Just for the heck of it tomorrow I'll check to see what the shop in my area does all that for and e-mail you the info.
