Where can I find wheel weights for a Ford 851?
Patrick Russell
02-15-2006 11:03:21
I appreciate everybody"s responses to my brush hog research. I am now wondering if and where I could find at least a pair of front wheel weights for the old Ford 851..? Any suggestions?
Thanks,
Pat
Dean
02-15-2006 13:43:31
 Re: Where can I find wheel weights for a Ford 851? in reply to Patrick Russell, 02-15-2006 11:03:21
Original front wheel weights for vintage Fords are becomming hard to find and expensive. I have seen prices as high as $100 for a single weight (1/2 of 1 wheel).
Though I have not myself checked, I have been told that these weights are still being cast by Taylor Foundry. I have no contact information for Taylor but perhaps someone else does.
Dean
old
02-15-2006 11:42:58
Look around at a few tractor dealers and or slavage yards. You also might think about filling the front tires with fluid, that will add 100lbs or so to the front. If you have a bumper up front you also might find some suit case weights.
Patrick Russell
02-15-2006 17:12:28
 Re: Where can I find wheel weights for a Ford 851? in reply to old, 02-15-2006 11:42:58
Thanks for the response! Just wondering from an inexperienced and recent tractor owner what "Suit case weights" are?
old
02-15-2006 18:01:11
 Re: Where can I find wheel weights for a Ford 851? in reply to Patrick Russell, 02-15-2006 17:12:28
Thats sort of hard to explain. There weights that will hook over a bar etc and are about 12 inchs by 18 inchs and weigh around 85-100 lbs each. I use 6 of them on my back blade to hepl hold the rear end down but with a heavy loader like I have that the only way to go
