Order Ford 8N Parts Online
8N Purchase Advise ?
OliverDouglas
02-15-2006 13:55:33
My local impliment dealer has an 8N on the lot and I was thinking if I added a small bush hog, this would make a nice way to cut my weedy pasture and hills. It's worn, but it appears to all be there.
Anything in particular I should check for before I go for the checkbook ? Rust, leaks, tires and etc ?
ratface
02-16-2006 10:20:30
 Re: 8N Purchase Advise ? in reply to OliverDouglas, 02-15-2006 13:55:33
oliver, try searching the archives on this site. Type something like rollover tests and you should find plenty. Dell knows all about the tests conducted but he hasn;t been around much. some university rolled different tractors down hills to determine speeds and angles of when the beasts would flip. Can probably google it. Also talks about direction to mow, for instance mowing up and down and not across an incline. Also stuff about center of gravity and weight distribution of the beast.
Bryan in WI
02-15-2006 20:45:23
Just don't buy it if his name is Mr. Haney.
Bryan in WI
02-16-2006 12:30:11
 Re: 8N Purchase Advise ? (joke explanation) in reply to Bryan in WI, 02-15-2006 20:45:23
Just in case nobody got my joke, Oliver Douglas (the poster's name) was the guy on Green Acres.
His tractor was a "Hoyt-Clagwell" (really an old Fordson).
OliverDouglas
02-17-2006 15:57:02
 Re: 8N Purchase Advise ? (joke explanation) in reply to Bryan in WI, 02-16-2006 12:30:11
I have to pick a new screen name :)
Everytime I post here someone asks about Lisa or the tractor.
Thanks for the advise on the 8N... now if only it was green :)
Ratface
02-15-2006 18:40:29
what do you mean by hills? If they're like my hills they are miniture mountains and my 8N has a difficult time pulling the hog, going up the hills and fighting the brush. If you like the tractor buy it but be aware that they have their limitations,especially on rough terrain. You might consider a more modern tractor with adequate brakes, Rops, perhaps even 4 wheel traction and a little more HP. If you purchase the tractor at least take it slow and read up on proper mowing techniques on slopes.
Paul L - Ohio
02-16-2006 04:01:10
 Re: 8N Purchase Advise ? in reply to Ratface, 02-15-2006 18:40:29
This is a stupid question. Where would you find the proper mowing techniques on hills? I am interested in this.
Bruce (VA)
02-15-2006 17:13:17
The link to the Smith's site from Charles (below) will give you just about all the info you need to make an intelligent purchase. Do take some time looking at the entire site so that you will get an idea of what the tractor is supposed to look like & if it really is an 8N as opposed to a 2N or 9N. Like it says on the Smith's site, test the hydraulics by lifting a heavy implement. Make sure you start it cold & run it through all 4 gears, then restart it hot.
FarmerDawn
02-15-2006 16:01:54
I don't think you would ever regret it, I can say that. :-)
CT8N
02-15-2006 15:24:34
Here is a page from Smiths 8N with some pointers.
Link
Charles
LeeMo
02-15-2006 14:29:59
How familiar are you with the implement dealer. Most that I know of anyway don't want to sell junk. They'll go over them and check them out before it goes up for sale. You're on the right track it sounds like. Check for bad leaks, quiet engine, decent oil pressure, smooth hydraulics, no oil in anti-freeze or vice versa, decent tires, smooth operating clutch, easy starting, etc. I'm sure you'll get plenty more suggestions.
Good Luck, Lee
P.S. They're a great little tractor for the uses you mentioned.
