Idle Speed RPM
8N'r
02-16-2006 15:23:47
What do most of you set your idle at? The specs call for 400 RPM's but my 8N seems to want to quit running at anything under 500---To my "untrained ear" the engine sounds great at around 600 RPM.
hvw
02-17-2006 13:47:24
 Re: Idle Speed RPM in reply to 8N'r, 02-16-2006 15:23:47
My 52 idles fine at 400 rpm's but I don't like that because you can't even tell the motor is running. Just kind of bugs me. So I always move the throttle to 5 or 600.
B. Jones
02-17-2006 04:09:23
I really like the term "trained ear ". I have mine at about 600 rpm also. I just like the sound at that speed better. It will idle at the 400 but it just sounds toooo slow to my "trained ear ".
K.LaRue-VA
02-16-2006 16:42:01
Just swapped a better carb onto my 9N engine. Throttle shaft on the old one was completly worn out. The new carb is not a MS but it idles down to around 400 RPM and runs much better.
8N'r
02-16-2006 16:07:03
Thanks Walt and Jim---I will let it alone at 600 where it seems to run the best!
Walt(LA)
02-16-2006 15:51:07
I have completely rebuilt 52n. idle 600rpm no problem. runs good Walt.
JimNC
02-16-2006 15:47:24
I"ve been around some that you can hardly hear running at 400 rpm. Mine I think is up around 5 or 600 and it sounds fine to My "trained ear". Personally I think 400 is too low.
Jim
gahorN
02-17-2006 22:45:57
 Re: Idle Speed RPM in reply to JimNC, 02-16-2006 15:47:24
I think 600 is good too! In fact, the 400 factory "recommendation" is kind of a goofy, misleading thing, IMHO. For one thing, long periods of very slow idling starves upper cylinders of oil-splash lubrication and can lead to excessive piston temp and sleeve wear. Higher rpms keep oil slung up there and keep the piston cooler and the upper cylinder better lubricated.
